Turbo experts, need help! (turbo math)
I'm in the process of doing some calculations to predict the efficiency of the turbo I want for my car. Using the equation:
Airflow (cfm)= (cubic inch) x (RPM) x (0.5) x (volumetric efficiency) / 1728
After I add in all the figures for my GSR, I get:
Airflow (cfm)= (109.7) x (RPM) x (0.5) x (.85) / 1728
* I set the volumetric efficiency to this average because a typical I-4 put out about 0.8-0.9*
Now my question is, what RPM should I set? Peak torque at 6200 or peak power at 7600? This is the RPM where I want the most efficiency out of the turbo, that is why I dont want it at redline. Any suggestions? Thanks.
[Modified by fiebru1119, 12:33 PM 8/13/2002]
Thanks! Now about the RPM part, this is where I want the peak performance out of the turbo right? If any of you guys did used this formula, what RPM did you use?
I think you'll want to use your max rpm. Don't hold me to it though
You may or may not have seen this site...
http://www.turbofast.com.au/javacalc.html
...some good calculators on there. But, like anything that I didn't create myself, I take it with a grain of salt.
You may or may not have seen this site...http://www.turbofast.com.au/javacalc.html
