Hissing Sound from behind water pump
Old Mar 21, 2009 | 11:27 AM
RA121924's Avatar
Default Hissing Sound from behind water pump
93 Civic Coupe EX, 1.6L, 5sp, 250k miles
I've had a slow water leak for several months and I can smell antifreeze on hotter days. From time to time there would be a hissing sound (stream) from behind the water pump area. The engine has lots of miles (over 150k) and I have no service history.
Hoping it would be something cheap I replaced the connecting tube o-rings and the hose which connects to the tube.
Took it for a quick drive with only water in the radiator, same sound from behind the water pump.
Could it be the water pump?
Old Mar 21, 2009 | 01:50 PM
Former User's Avatar
Default Re: Hissing Sound from behind water pump
The noise might be caused by air trapped in the cooling system. Push the heater lever to max heat, drain all the water (=bad) out of the system, refill with 50/50 coolant, and then bleed the system:
new_climber
16
Mar 12, 2018 08:56 PM
Champs32
Feb 13, 2009 11:32 AM
blackeg
Oct 11, 2007 02:25 AM
redsolturbo
Feb 7, 2007 09:34 AM
bobbyh
Mar 30, 2002 12:39 AM
