help please: H22 Swap will not rev past 4K
Old Mar 21, 2009 | 09:41 AM
ninty2preludebb4's Avatar
New User
Default help please: H22 Swap will not rev past 4K
i just did an h22 motor swap in my 92 prelude. it will not rev over 4 grand any one kno why this could be
Old Mar 21, 2009 | 12:29 PM
mattsnooz's Avatar
Default Re: help please
Any Check engine lights?
Whats happening? Like fuel cut out?
Old Mar 21, 2009 | 12:57 PM
Kronn 98SH's Avatar
which ECU are you using?
Old Mar 21, 2009 | 10:39 PM
MikeLuder's Avatar
Default Re: help please: H22 Swap will not rev past 4K
somethings seems completely out of whack. Even the wrong ECU wouldn't cause a 4k cutoff? p13/p14 should at least take it to about 6k even if you were in 'limp mode'
any check engine lights?
Possibly the TPS being completely set wrong? I know that can throw everything off
Old Mar 21, 2009 | 11:26 PM
ArmaanOG's Avatar
check the map sensor and deff get a new ecu make sure you got right distributor also
Old Mar 23, 2009 | 09:40 AM
h22bush's Avatar
check and see if the TPS and the EGR valve pigtails aren't switched. I swapped those two and it wouldn't rev past 35 so that could be your problem.
H22CIVICJDM
Jan 8, 2007 09:00 AM
acclude-vtec
Jan 8, 2006 08:57 AM
7speed
Mar 9, 2005 12:42 PM
H22edAccord
Apr 18, 2004 05:29 PM
93R33Lude
Mar 2, 2004 05:48 PM
