clunking noise on front driver side after suspension install..
well, i decided to put my suspension on last weekend and just to note before i put the new suspension on, i never had this noise before..so anyhow I put the new shocks, rear lca's and coilovers on, and now i hear this very loud clunking noise when i hit small or big bumps and it definately sounds like its coming from the driver side.i owned a lowered car before and i know what normal bump sounds sound like and this definately isnt 1 of them. Im pretty much eliminating a bad balljoint simply because this noise didnt come about until after i ****ed with the car. The shock setup is correct, the bumpstops are all on as well as the gaskets. im going to try to torque all the bolts when i get out of class here shortly because it def sounds like the shock tower itself is loose. what are some other possibilities this noise can be? i was told to double check the control arm bolts even though they werent touched..
slateEKsi
15
Aug 10, 2021 04:43 PM
