front jdm itr 5 lug suspension question...>>
whats good guy's, i need some help with my front jdm itr 5 lug suspension..i install it on my 95 integra and am stuck...the lower ball joint from the jdm itr suspension is not going into the usdm 95 integra front, lower control arm ball joint hole...the screw from the jdm ball joint is too big....where can i find a ball joint that would work for me......?...please help me out ............thank's guys for your time.......
this is my stock front suspension and the jdm.....the ball joints are different....check the picture..what ball joints can i use to replace and make it work...
press your old ball joint out of your old knuckle and the put it in the new knuckle...the ball joints themselves are the same, its the threaded part were you bolt the nut on that is different
the jdm ball joint is bigger from top to bottom....i dont think it would work....the stock one is way to small for the jdm nuckel.....
while your at it did you check if your axles will go in onto the hub? cant really tell if there he same size, but i agree with boots your going to have to change the lower control arms. and also you rear lower control are is different. gl
..........i got this now..am hit up the hole of the front lower control arm with a drill to make it bigger so the screw from the jdm ball joint could fall right in place.....ill keep ya up dated on how it went down...also am pick up some h22 axels for the outer joint to bond the B axels with the H22 outer joint....
For a 5 lug conversion in the front of an integra you just need us itr hubs and a 5 lug rotor of your choice. Running jap hubs is stupid, you can no longer buy axles at any honda dealer or auto parts store.
who else went through this problem...?..or am i the only one.........help me out.....i dont want to shave the hole down yet...i need more info....
problem solve..they had sold me the wrong 5 lug suspension..i went back to engine depot and got the real jdm 5 lug..it bolts right up...
Those steering knuckles are not from an Integra, the USDM and JDM both took the same knuckle and ball joint. Based on that caliper and knuckle, I bet that knuckle is from a Prelude (97-01)
CXHatchback
Jun 5, 2003 09:22 PM
