How to remove fabric portion from civic si /crx si panel
Old Mar 20, 2009 | 09:54 PM
JokerX-1.6T's Avatar
Default How to remove fabric portion from civic si /crx si panel
Who can tell me how to remove the fabric portion from a civic si /crx si door panel ? and install on another panel
Old Mar 23, 2009 | 06:24 PM
Canadian_EF's Avatar
Default Re: How to remove fabric portion from civic si /crx si panel
it is easier to just swap the panel...
I think it is glued on.
Old Mar 24, 2009 | 08:35 PM
scottmog's Avatar
But if ur taking the panel from a door mounted seat belt to a non or the other way around. Ull either have a hole where u don't need one or u won't have one when u need one. Answer about that?
Old Mar 24, 2009 | 09:02 PM
Tyson's Avatar
it just rips off. its not made to be swapped. i suppose you could glue it back on, but the edges are not going to be nice.
Old Mar 24, 2009 | 09:03 PM
Tyson's Avatar
youd more to worry about than the seat belt slot. the door panels shouldnt be swapped across years unless you really dont care about how it fits.
Old Mar 24, 2009 | 09:45 PM
scottmog's Avatar
How it fits? They all are the same size tyson lol. That doesn't make any sense.
I'm putting a 88 crx panel on my 90 crx si after doing a door to pillar belt swap.
Old Mar 24, 2009 | 10:14 PM
Tyson's Avatar
well you cant put the 88 door panel with door mounted seat belts....
your original question doesnt make any sense.
Old Mar 25, 2009 | 02:34 AM
ef yu's Avatar
since you didn't want to replace the whole door panel itself, i assume you know that it doesn't fit already.
soo...
you have a 88 SI door panel with the "crx" logo and you want to remove that "fabric" portion w/the crx lettering and place it onto your 90 crx door panel that didn't come with the "fabric" portion. right?
well your going to have a problem.
88 crx si door panel have NO door mounted seat belt. therefor the "fabric" portion is longer.
if you compare a 88 door panel to a 90/91 door panel, you will notice that the "fabric" portion you want to remove are in fact different sizes.
also i have tried to remove the 90-91 seat belt mounted door version, and they do not come off. you will have to actually cut it off the door panel. not sure about the 88 models.
(not my pictures, im sorry if these are your pics, please PM me if you want to take them down. )
bprsk8r4272
Mar 18, 2012 08:42 PM
dank714
Jan 10, 2011 08:05 PM
bb4ninja
Dec 16, 2005 05:18 PM
bb4ninja
Nov 20, 2005 09:15 PM
b18dreams
Mar 6, 2003 08:56 AM
