Smokin' hot exhaust
Old Mar 20, 2009 | 07:33 PM
88dxhbdaily's Avatar
Default Smokin' hot exhaust
So i got an 88 dx hb for a daily and its got some issues... it will almost always start on the first try so no issue there, however it sometimes has a very erratic idle, losing power, popping and once in a while it completely stall. A couple of days ago it was losing power.. poping and then a very loud pop and sparks flew out the back of the car... any ideas?
it has a new cap and rotor for the dizzy, new gasket for the dpfi throttle body and i replaced most of the vaccum lines... thanks all for what help you can offer
Old Mar 20, 2009 | 09:15 PM
fatboy1185's Avatar
Big Cat
Default Re: Smokin' hot exhaust
is the cat clogged?
Old Mar 20, 2009 | 09:39 PM
Thats the first thing i thought however these symptoms come and go sometimes it will run perfect... of course ill have to either drive 80 miles to get my jacks and stands to get under it.(which i wouldnt want to do for obvious reasons) or go buy a new set... thanks for the idea...any other thoughts...anyone?
Old Mar 20, 2009 | 09:43 PM
fatboy1185's Avatar
Big Cat
did you check the plugs
Old Mar 20, 2009 | 09:50 PM
plugs are "clean" ... actualy thats the first thing i checked... timing is ok but the cover is ****ed so im pretty sure its not 100 percent...
Old Mar 24, 2009 | 05:59 PM
bump
Old Mar 24, 2009 | 07:39 PM
slammed4dreg's Avatar
sounds like your running to lean, and your cat IS getting clogged up. my moms minivan is having the same problem, it turns on quick but when driving it starts bogging out backfiring and the fumes coming from the exhaust is really really hot. is it throwing any codes?
Old Mar 25, 2009 | 06:44 AM
thats what gets me... no cel... it works cause it lights when the car turns on but other than that no
Johnny1989
Dec 4, 2013 05:49 AM
Jonathan6229
Jan 3, 2013 07:15 PM
kevodean
May 9, 2009 01:50 PM
[626]95-GSR
Sep 30, 2002 03:59 AM
