Engine Hunting
Old Nov 26, 2013 | 11:11 AM
Johnny1989's Avatar
Default Engine Hunting
OK I'm Going to start this thread with everything that I have done/ replaced.
I have replace the dizzy.
Throttle body (the old one was sticking bad)
breaks
patched the exhaust.
Changed wires and spark plugs.
Replace all the seals from the head gasket and up. (Alot of work)
Had to reset the timing belt and timing on the cams.
Checked all my vacuum seals.
Replaced the entire clutch.
Replaced oil sensor.
and 1 axel
Now the throttle body was my last problem. And my idle is hunting high and low. I've cleaned the iatv. And im at a loss. I've put soooo much money into this car and I just can't get it right. The car was also a convertion (and done poorly). I'm on the verg of selling it but I just picked up new tires and rims. If anyone has somthing I can check let me know! I'm so fusterated.
Old Nov 26, 2013 | 11:47 AM
B_Swapped93's Avatar
Default Re: Engine Hunting
bled the coolant system after right ? checked for VAC leaks, adjusted the idle screw ?
Old Nov 26, 2013 | 04:45 PM
safedriver's Avatar
Maybe the coolant system needs burping.
Old Nov 27, 2013 | 07:31 AM
tamboo's Avatar
10 Year Member
haynes says check for:
vacuum leak
leaking egr valve
clogged air filter
insufficient fuel pump pressure
head gasket leak
timing belt and/or pulleys worn
camshaft lobes worn
Old Nov 27, 2013 | 11:28 AM
standy xsi's Avatar
try blocking the holes in the throttle body one at a time and see if that works or not. post back after
Old Nov 27, 2013 | 12:38 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Take apart the FITV. Look at thr large plastic "cap" looking thing on the inside. Tighten it back up. Reinstall. Witness miracles.
Old Dec 4, 2013 | 05:49 AM
HondasSuk's Avatar
There's videos on youtube showin how sove idle issues, ^ like the guy above me mentioned, good luck.
john d
Mar 10, 2015 02:41 AM
RuneRavenX
17
Nov 9, 2012 02:42 PM
Rob.
Jul 15, 2009 01:26 PM
teggyhill
Jul 14, 2009 02:12 PM
96b16sprayin
Mar 16, 2009 12:45 PM
