ingalls front camber noob help
i orderd a front caber kit for my 04 dx and on inspection i noticed that i cant thred the nut all the way down the bolt im a noob so im not sure if it stops itself or the threads are just messed up it seems like theres flat spots on the nut this is as far as i can thread it by hand is this rite ?????????
ok the torque for the front camber bolt according to ingals is 125 ft pounds and according to honda it is 76 ft pounds which is correct i have a 2004 vp.?????????
You have to crank the camber kit bolts down more because you want them to stay put. So if you're using stock bolts, use the Honda spec, if you're using the camber kit, use the ingalls spec.
Ok, still no answer, i seen the pictures on the top of the page that doesnt do me any good im talking about where do they go on the car and how do they sit?
lol
FAQ's: https://honda-tech.com/forums/showthread.php?t=2247386 (remember these?
Camber kit DIY: https://honda-tech.com/zerothread/1664914
)Camber kit DIY: https://honda-tech.com/zerothread/1664914
raidacaipo
13
Oct 14, 2009 10:05 PM
allmotorEG-SI
Suspension & Brakes
Mar 12, 2005 11:26 PM
