D16z6 head on D16y8 block, few questions...
I filtered through the search engine but did not find any concrete info.
Car: 99 Civic Ex with d16y8.
The timing belt broke on the vehicle, consequently, a few of the valves are bent on the y8 head. I have a good spare D16z6 head that I would like to use rather then repairing the y8 head.
-I'm aware that I need to run the y8 headbolts, except for one z6 headbolt next to the vtec solenoid.
1) Can I use the original y8 cam and camgear on the z6 head without any cam timing issues? Or do have to purchase an adjustable camgear or use a z6 camgear? I'd like to run the y8 cam because I intend to use the stock y8 ecu.
2) Will the original y8 OBD2 distributor bolt up to the z6 head?
3) Any other issues to be aware of? Btw, I plan on using the y8 intake manifold.
TIA
TIA
You have to use a Z6 distributor with Y8 CYP/CKP/TDC sensors, or use an adapter harness. You may have some issues with the '99 - '00 Y8 using air injection/cold start assist.
thatseemslegit
Aug 30, 2015 01:45 PM
