bogging and hesitation with fresh b20
Old Mar 20, 2009 | 04:21 PM
killahatch's Avatar
Default bogging and hesitation with fresh b20
hey guys i just put a b20 in my hatch and there seems to be a few problems with how it is performing right now. when the car is cold it runs like a champ but when it warms up it starts to bogg and hesitate when you press down on the throttle. few things about it. its a b20b with a phearable chipped ecu, exhaust, intake,ngk plugs and wires, and its throwing the iac sensor code thats it.
any ideas would be greatly appreciated.
Old Mar 20, 2009 | 05:52 PM
Meoshe's Avatar
Default Re: bogging and hesitation with fresh b20
Try cleaning the IAC, it's the code it throwing so it MIGHT be bad.
Old Mar 20, 2009 | 10:35 PM
killahatch's Avatar
i cleaned it before i put in the motor. its bogging bad enough that i can barely beat sohc non vtec. the reason why its throwing the code is because it was grounded wrong.
would the iac cause that bad of a power loss, bogging, and hesitation?
Old Mar 21, 2009 | 06:13 AM
ltrkstr2k's Avatar
double check ya timing.when i did my ls swap i had the same thing i redid the timing and it came alive
Old Mar 21, 2009 | 06:56 AM
killahatch's Avatar
as in dizzy timing or cam timing. i set it back to the middle after messing with it. all the local ppl keep telling me that but i kinda lost hope that its the timing after messin with it for hours. ill recheck it though.
Old Mar 21, 2009 | 07:08 AM
TravisCadello's Avatar
i doubt its the timing then... This sounds like the same problem I had with my Sohc v tec. it turned out to be the TPS Sensor.
Could be the MAP Sensor Also. They Both Will do what your talkin About.
Old Mar 21, 2009 | 07:15 PM
killahatch's Avatar
just put in anotehr map sensor and its acting alot better. im gonna try driving for a day and see if a can and my friends can tell a difference and then i'll post up the results.
thank you so much.
demael93
Oct 25, 2013 05:27 AM
blasterman87
22
Sep 25, 2009 07:50 AM
1_slo_ef
May 8, 2007 05:27 PM
88 rex
Dec 14, 2006 11:16 PM
IWearMyKswiss
Dec 8, 2001 04:14 PM
