Mounted Point?
Old Mar 20, 2009 | 11:30 AM
b00stedbyFastrax's Avatar
Default Mounted Point?
what sort of mounted point is used for deburring aluminium. the ones i am using seem to stick to the material on the mounted point.
Old Mar 20, 2009 | 03:48 PM
got wide's Avatar
Default Re: Mounted Point?
not sure what your talking about but ive used everything from a die grinder to the corner of a bench or table to deburr al tubing.
Old Mar 20, 2009 | 03:55 PM
RyanA's Avatar
You mean the aluminum is sticking in your bit? If so, you can use some PB Blaster, WD40, etc on your bit and on the aluminum to keep the aluminum from getting stuck in there. If you are going to weld, you will either have to clean it up really well afterwards or just keep doing it the way you have been. You ARE using a non-ferrous bit, right? It's the style with the serrations farther apart....
KtHaNxBai
May 25, 2012 07:32 AM
Dr Pooface
Welding / Fabrication
Mar 21, 2011 03:24 PM
MindLess311
14
Feb 14, 2009 06:17 AM
stackz
Aug 29, 2007 02:33 PM
TurboSI56
10
Jun 8, 2006 04:56 PM
