1993 Del Sol Aux. "Lightmare"
Old Mar 20, 2009 | 11:26 AM
ALLmotorACE's Avatar
New User
Default 1993 Del Sol Aux. "Lightmare"
Ok, so I followed one of the ways to do the aux. light trick, and it definitely did not go very well for me because I blew my relay. Well, I rewired the car back to normal, got a new relay, and it still didnt work. So then I did another aux. light trick and got another new relay, and again the lights do not work. My aux relay keeps on clicking everytime I go to switch the aux. lights on.
Right now i have the red/white aux wire from the switch wired to both sides of the black/yellow wire from the rear defroster switch. And the other side of the red/white aux wire is taped off so that it wont come in contact with anything else. I checked the under-dash fuse, and that is totally fine too. Does anyone know what else I can try to do to get these things working without re-wiring the whole entire thing?
Thank you in advance for any help.
Old Mar 22, 2009 | 12:08 PM
New User
Default Re: 1993 Del Sol Aux. "Lightmare"
anyone?
Old Mar 22, 2009 | 12:53 PM
trustdestruction's Avatar
i used the instructions on solsociety and they didn't work for me, or i read them wrong.
here's what i have:
at the harness behind the aux light switch, cut the red/white wire.
strip some insulation off the red/black wire.
Now, what you are going to do is attach the red/white wire (the now cut wire hanging off the harness plug to that stripped insulation on the red/black wire.
The other cut end of the red/white wire will be left alone. tape it off or put a crimp cap on the end.
in this diagram i have only labeled the wires you will be using. their location on this diagram is not exact, just go by the labeled color.
Honda CR-V & Element
Apr 29, 2015 10:42 AM
dwnthehatch
17
Mar 12, 2010 02:34 PM
z6hatchboy
Dec 24, 2009 06:14 PM
rugimpy
Audio / Security / Video
40
Dec 2, 2009 06:51 AM
wolf95
Lighting
Sep 24, 2009 11:45 AM
