Help: Viper Alarm/Car wiring 97ex civic
Hey,
I would like help identifying the wires that I need to tap into for the alarm to work. I have the installation Manuel but I just need to identified the wires that I need to connect it to. I have a 97 ex. So if some one is knowledgeable in Viper alarms. I have some question I would like to ask you through PM, I don't want theives into the conversions!!
All the info you need is here: www.bulldogsecurity.com. Then, click "Wiring Diagrams" at the top and go from there...
And BTW...
on you for bumping after 45 minutes... Be patient around here or GTFO.
where do the H1/6 violet wire (+) door trigger wire connects to on the civic? what wire color?
where does the light green wire on the shock sensor goes?
where does the H1/10 white/blue remote start(1-) activation input goes to? or does it need to be ground?
white/blue wire is used to activate any modules used for the remote start
(bypass modules)
You have all of the correct & prudent information, yet you still can't follow directions?
Let's not confuse the OP any more then he already is, although you are correct that he does not need the violet, [+ door trigger input] you are wrong about the white/blue, it is an input, NOT an output, it is used to trigger the remote start, the same as pressing the remote start button on the remote control.
What your talking about is the status output lead [blue and/or blue/white]. 94
Dude. Seriously I appreciated for giving me that website, but if you can't help me on these questions, don't get an attitude or be a smart *** . I'm trying to learn how to wire, and the directions are vague on some. I just wanted to clarified it, before I hook up something wrong to it.
Thank you, for answering my questions orangebang49 and fcm.
Check you pms, I have some questions for you about installing the viper alarm.
look man heres the wire u need and u better do a clean job no stuffed wires ok!!..........
from the alarm- car
Red - 12+ white ignition harness
black - Ground tap or drill screw onto metal
white - parkinglights Red/Black u can find this wire on the illumnation ****
green - door trigger Lt.green/red driver kick panel
blue - unlock green/orange blue harness under fuse panel or behind radio anti theft module
green - Lock green/white blue harness under fuse panel or behind radio anti theft module
the rest as far as igntion wires i need to know what kind of viper alarm u got????
from the alarm- car
djbrandonr
Audio / Security / Video
May 12, 2006 12:56 AM
