help with 94 Integra Door locks problem
Old Mar 19, 2009 | 09:07 AM
lazii_boi08's Avatar
Icon6 help with 94 Integra Door locks problem
My friend just got a 94 Integra LS with a jdm b18c swap and the previous owner had mentioned that he had changed the whole dash harness prior to the swap (dont really know why?..) and I am trying to connect his alarm and door looks dont work i checked the fuse it fine so my guess is it due to the changing the dash harness that somthin may have not been connected??? or is there a keyless module missing ???
Old Mar 19, 2009 | 11:40 AM
fcm's Avatar
fcm
Old Fart
Default Re: help with 94 Integra Door locks problem
The 94 LS did not come with stock power door locks, so they are either aftermarket or OEM ones have been installed from a GSR or something, that may be why the dash harness was changed.
Is there a power door lock switch and does it work? 94
Old Mar 19, 2009 | 11:52 AM
shietzitzkien's Avatar
does his aculator (sp?) still work? might be a noob advice though.
Old Mar 20, 2009 | 03:19 AM
jdmjoka's Avatar
DB squad #282
you sure about that?
Old Mar 20, 2009 | 05:36 AM
fcm's Avatar
fcm
Old Fart
Pretty sure, I have a 94LS, although it would not surprise me if USDM and CDM G3 LSs are different
Old Mar 21, 2009 | 09:29 AM
I tryed checkin the 2 wires for lock & unlock and theres no voltage and yes there is a switch and its not working and I thought all integra comes with power door locks.... and i doubt the stock actuators are dead even though i got the after market ones 2 but i dont really feel like goin through the hasle
Old Mar 21, 2009 | 01:00 PM
jaysmoke's Avatar
New User
You can use 2 relays and your alarm to trigger the doors if you cant figure out what he had goin on.
Old Mar 21, 2009 | 03:26 PM
fcm's Avatar
fcm
Old Fart
The "two wires" for door locks are ground supplies, the door switch supplies a ground to the "Power Door Lock Control Unit, when pressed, [black/white for lock and black/red for unlock].
As I said I have a 94 LS and it did not come with power door locks, power windows yes, but no power door locks, I added aftermarket ones.
If you door locks are not working off the switch they will not work off the alarm, something is not plugged in properly.
Check to see if there is power at the door lock fuse, fuse 6 - 20A, [hot at all times] in under dash fuse box.94
Old Mar 22, 2009 | 07:19 PM
yes you see i checked wire wit a meter an the button does work i juss think the door lock module on the driver is mested up cause i dont hear click when pressing the lock button
re rex
Nov 20, 2013 01:51 PM
Acurazor
Dec 27, 2008 06:13 PM
97integraLS911
Mar 21, 2007 01:29 PM
SiRTifiedacc
Aug 7, 2006 05:03 PM
vtec95
Jul 18, 2006 09:36 PM
