Need help on swap
Old Mar 20, 2009 | 10:30 AM
siR90hatch221's Avatar
Default Need help on swap
Ok i have a sohc zc with a vtec head i just swapped it into a 1990 honda civic hatch dx to make things easier i did the dpfi-mpfi conversion and bought a obdo-obd1 jumper harness so i could run vtec i have everything wired up but for some reason its not getting any spark what so ever the motor will turn over but nothing happens.
Please help
Old Mar 20, 2009 | 12:12 PM
Default Re: Need help on swap
Please help
anyone?
Old Mar 20, 2009 | 12:42 PM
dohc_star's Avatar
Have u checked power to the euc have you checked power to the dizzy allso check the ground that go's to the thermistat housing then get back to me
Old Mar 20, 2009 | 05:03 PM
vtecb18c's Avatar
i would start with your dizzy....possibly your ignitor is bad...but yes as stated^ check all possible grounds...have you tried to see if its throwing any codes?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Mar 20, 2009 | 05:46 PM
Ok ill check tomorrow.
Old Mar 20, 2009 | 09:35 PM
ef_b18a1's Avatar
alright, i did a b18a1 swap in my hatch ( i blew it up a few days ago) anyway i had the same issue... i bet your not getting spark and fuel... 1rst make sure you have the thermostat ground on! 2nd check your fuse box on your shock tower under the hood... i spent 4 ****ing days tryin to figure out why my car wasnt getting spark and fuel and ****, and it was a 30amp fuse... i was sooooo pissed.. those were the only issues i had...
Old Mar 20, 2009 | 10:26 PM
Yes exactly im not getting any spark or fuel i hope thats all it is i'll check on it in the morning and let you know what happens.
Old Mar 24, 2009 | 08:19 AM
Ok I did everything you guys told me im getting fuel now but still no spark.
Old Mar 24, 2009 | 08:49 PM
It started up today thank you guy for all the help it was the distributer.
epic_vtec24
Dec 27, 2014 05:33 PM
siR90hatch221
Dec 16, 2008 07:41 PM
biscuit51
Feb 9, 2008 07:48 AM
Sohc_hatch91
Nov 25, 2006 07:21 PM
1 del slo
Nov 13, 2002 09:13 PM
