crx b16 transmission leaking
i have a crx with a 1 gen b16 obdo stock tranny s1. i havent drive the car that much i just finished the swap and i have integra axles. for some reason when i put fluid on the transmission it leaks it out the axle seal where the intermediate shaft goes . i replace that seal got it from a 91 crx si single cam motor i bought at the dealer becuase that is the only seal that is the same size as the jdm seal. all the other b series where bigger. so i dont know how to resolve this problems . what not working the axles the seal the shaft. any help will be appreciated.
I am pretty sure that you need to use the seal from a B16/B18 tranny. Make sure you are using the correct intermediate shaft too?
Here are some good resources:
https://honda-tech.com/forums/tech-misc-15/half-shaft-help-please-2425985/
http://www.hasport.com/news/articles...t%20Axles2.htm
trust me i bought the seals from a 99 civic si from a 95 integraa from a 91 integra basically all the models even the delsol b series . they were totally different size. until i went to the honda dealer and he pulled out one for a 91 crx si single cam and it was exactly the same size.
the intermediate shaft is the correct one i bought the complete engine swap with tranny and motor all put together i bought off a warehouse in montereal canada.
What part #s are you using?
Does the intermediate shaft enter the differential?
90 integra Acura part# 91205-PL3-B01
RACING INTEGRATION
Mar 3, 2006 08:09 PM
