what turbo to buy for 450hp.
Old Mar 20, 2009 | 08:03 AM
IceySC's Avatar
Default what turbo to buy for 450hp.
if anyone can help me it would be great i just finshed braking in my new motor and im looking to pick up a turbo this coming week and im lost.
my motor set up.
81.5mm gsr bottom end
eagle rods
wisco pistons
block guard
all arp bolts
head is also gsr that has been ported and polished by endyn
endyn flat top valves
itr cams
str cam gears
hondata intake manifold gasket
jg intake manifold
bdl 68mm throttle body
p2r throttle body gasket
golden eagle fuel rail
my turbo setup i have so far
peakboost ramhorn manifold
peakboost down pipe and dump pipe
38mm tial wastgate
2.5 inch piping
600hp intercooler
walbro 255 fuel pump
for tunning i have hondata s200
so im just needing some injectors which i was going to order today precision 880's
and as for the turbo i was looking at the precision sc61 and the sc60 im trying to hit 450whp with out boosting a ton of boost and something with a good spool time.
Old Mar 20, 2009 | 05:24 PM
IceySC's Avatar
Default Re: what turbo to buy ??
bump
Old Mar 20, 2009 | 06:34 PM
wpgredteg's Avatar
i've heard many good things about the sc61. that would probably be a good choice.
Old Mar 20, 2009 | 09:42 PM
IceySC's Avatar
thats what i was thinking but i heard a few things about the sc60 . some have told me that i would be around 5000 rpms at full boost with the sc61 so i was think with the sc60 it maybe alittle lower.
Old Mar 21, 2009 | 07:49 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: what turbo to buy for 450hp.
you could come close on a 60 trim
gt30r would be the best option as far as garret goes
Old Mar 21, 2009 | 07:55 AM
TheShodan's Avatar
Moderator
It'd look to a BW258 or 60-1 Silver surfer. That would be fantastic based upon that build for 450whp and reach maximum pressure faster than an SC61 by quite a bit.
Old Mar 21, 2009 | 10:08 AM
rocket256's Avatar
A GT30R will get you there but it will be leaning toward the end of its limits.
The SC61 will get you there with ease.
And the GT35R will diff... get you there w/ a lil fast spool then the SC61
I hit 462@16psi on my B18C w/ SC61E
Old Mar 21, 2009 | 11:30 AM
SuperTeg95's Avatar
I made 430wph at 14.5lbs. Its a great turbo for that power. You don't want a turbo that maxes out at what your peak power. The SC61 has the ability to allow more power if your set up changes.
Old Mar 21, 2009 | 11:35 AM
quicksilver1689's Avatar
i ♥ snails
get an holset hx35
Old Mar 21, 2009 | 01:09 PM
TheShodan's Avatar
Moderator
Its not just that a turbo gets the power, but HOW you WANT that power delivered with the budget..
Old Mar 21, 2009 | 01:24 PM
mangina's Avatar
30r on pump @ 15psi 438whp
Old Mar 22, 2009 | 10:39 AM
IceySC's Avatar
thank you all for the info . superteg95 is the one that built the motor for me .
Old Mar 22, 2009 | 01:12 PM
TurboK's Avatar
S400 is your best friend.
Old Mar 22, 2009 | 05:58 PM
Silva Bullit DC4's Avatar
Old Mar 22, 2009 | 06:14 PM
HamiltonRex's Avatar
if i were you, id go with the s256 or s259 (I don't believe they make a s258 anymore).
The s256 will be great, and the s259 can support 600hp, and the s256 still 550hp. go with the 0.70a/r vband exhaust housing.
I run the s258 0.70a/r on my dsm and its an awesome pump gas turbo.
Old Mar 22, 2009 | 06:34 PM
TheShodan's Avatar
Moderator
s258 still exists, just in limited quantities.
Old Mar 22, 2009 | 07:36 PM
ProjectBB6's Avatar
The SC61 would get you there no problem... might also want to look into the Silver Surfers Shodan is talking about.
Old Mar 22, 2009 | 08:56 PM
4drlsvt's Avatar
id say gt30 or a holset if your on a budget but i would lean away from 880's i would got 750 or 1000 880 are hard to deal with as far as tuning im actually selling mine because of it to go with 1000cc bosch im looking for same power i have precision pt67 because i got a good deal on it
Old Mar 22, 2009 | 10:08 PM
IceySC's Avatar
i want the bosch injectors but they are just way to high at this time . ive never herd anyone talk about 880's given people issues.
Old Mar 22, 2009 | 10:37 PM
blinx9900's Avatar
I had the same goal and grabbed a GT3076r and I am very happy with it, i have also driven many turbo cars and turbo honda's but then again this is all subjective... fyi i never reached the 450 goal though...
Old Mar 23, 2009 | 12:25 AM
99V-unit's Avatar
how much power did you end up making. I got a built b16 block laying around. i was think to throw in a gt30 at around 20psi. what rps you have full boost..
Old Mar 23, 2009 | 03:01 AM
4drlsvt's Avatar
boschs are a little pricy but not that bad you can get a set and a walbro 255 from xenocron.com for 500
Old Mar 23, 2009 | 03:07 AM
blinx9900's Avatar
I made 333whp at 12psi with 91 octane, 8.3 compression and a b16b head, not too shabby imo I also have a 3" turbo back exhaust. My car weighs 2250lbs so it moves as is so i just left it at that power level :D I never really look at the tach and its been a while since i data logged the car so I'm not sure where full boost comes in at but its just right for me, i can drive around on the motor no problem and step on it when i want boost, i personally like and want a little bit of turbo lag.
Old Mar 23, 2009 | 06:10 AM
TheShodan's Avatar
Moderator
Did 346 and 250 ft/lbs with a silver surfer at 11.6psi of pressure, and saved over $300 plus the cost and wqork of the water lines. This was on a 9.8:1 GS-R, thanks to Mitsuman:
http://www.hondamarketplace.com/show...&highlight=sls
Here's his video:
http://smg.photobucket.com/albums/v2...=dyno346hp.flv
Old Mar 23, 2009 | 06:42 AM
Here's his video:
you say that like water lines are expensive or hard to do... water lines can be done for under 30, or even nice stainless for about 120 (b&r fittings kit)
i still say 60 trim would get you close and be cheapest, or if you have the extra cash go with 3076r
