Running no thermostat while performing coolant flush?
Old Mar 20, 2009 | 03:14 AM
hotcivicsi's Avatar
Default Running no thermostat while performing coolant flush?
Going to perform a full coolant flush this weekend partially because I believe my thermostat is stuck closed. I've come to this conclusion because my lower radiator hose doesnt get warm at all and my fan doesnt kick on. When I do the flush I was wondering can I perform it without putting in the new thermostat? Only reason is I'm thinking if theres crap in the current coolant wouldnt it kind of clog it up?
Thanks guys
Old Mar 20, 2009 | 03:27 AM
instructor74's Avatar
Default Re: Running no thermostat while performing coolant flush?
yes you can do a flush without a tstat. however unless your car is overheating I don't think your tstat is the problem
Old Mar 20, 2009 | 03:43 AM
hotcivicsi's Avatar
It does overheat if im sitting in traffic and not moving....what else should I check?
Old Mar 20, 2009 | 04:28 AM
quapouh's Avatar
Check the radiator fan, if it doesn't kick in when temp gauge is above half it means that either fan, relay or fan automatic switch are to blame. Check continuity and voltage in this circuit.
... are u loosing any coolant?
Old Mar 20, 2009 | 04:57 AM
hotcivicsi's Avatar
fan doesnt kick on but I was thinking because the coolant isnt flowing where it needs too its not reaching the switch. Im going to check today if Im loosing coolant since I topped it off this week.
Old Mar 20, 2009 | 04:58 AM
hotcivicsi's Avatar
any how to's on checking voltage or the relay?
Old Mar 20, 2009 | 02:25 PM
hotcivicsi's Avatar
TTT how do I check the fan, relay or fan automatic switch?
Old Mar 20, 2009 | 02:34 PM
Former User's Avatar
The 2-wire fan switch is located on the thermostat housing. Remove the switch connector and jump it with a wire. The fan should run continuously when the key is in the ON(II) position. If so, the fan relay, motor, and circuit are fine, though the switch itself could be bad. Replace the thermostat, however, before worrying about the switch.
Old Mar 20, 2009 | 03:22 PM
hotcivicsi's Avatar
how do i jump it with a wire? just wire one of the wires to the positive battery terminal? sorry if i should like a newb just hate touching anything electrical, mechanical ont the other hand im great at haha
Old Mar 20, 2009 | 04:23 PM
Use a roughly 4-inch piece of wire with 1/4" of insulation removed at each end. Then insert each end of bare wire into each female terminal of the switch 2P-connector (=jumper wire).
Old Mar 20, 2009 | 04:46 PM
Christopherian1982's Avatar
I had the same issue with my b16... It was my t-stat! Replaced that and did a flush and just burp the damn thing.
Old Apr 9, 2009 | 06:19 PM
ihatesilver's Avatar
awesome, my rad fan is not coming on despite getting over 1/2 on the heat gauge. i'll test it tomorrow. very helpful.
dhonda00
Jun 11, 2013 04:14 PM
vlude99
Jul 30, 2009 05:58 PM
Twistedframe
May 24, 2007 08:26 AM
Cuda
Mar 21, 2007 11:25 PM
KB96VTEC
May 23, 2005 06:30 PM
