Honda Quick Lockdown's*unstealable*
Old Mar 19, 2009 | 11:49 PM
hammergunner's Avatar
Default Honda Quick Lockdown's*unstealable*
This is a re post of a earlier post of mine. AND....is in the forum only due to the fact EF's are the most easy honda's to steal out there.(I see alot of post here about stolen cars!!)
OK,
Everyone needs to know how to keep there car from getting stolen, But most of the time they never work. Sooooo i want to see what idea's you guys have. And i will share my best methods, in the hopes we can stop damn thieves once and for all!
1. Change Locks. (almost all thieves use keys these days, so change them locks to none standered keys, I.E Lockbox keys)
2. Get rid of locks. (use the handle off a 4 door model of your car, if they offer one, and get rid of those locks. Use of pop locks in the best and easyiest way for this to work)
3. Injector Relay Plug/Resistor box, (removing this plug/box will disable the injectors so no gas will shoot into the motor, thus killing the car.)
4 . Take ECU, (you can't start what has no power, taking of the ecu will kill all power going to the engine.)
5. Kill switch,( a switch hidden under the seat or another place in the car with easy access
can stop the starter in its place and keep the motor from cranking.)
6 . Alarm, ( most thieves will just walk away if they see an alarm. And better yet make it seem like you have a viper alarm and use a Bright Blue Led Bulb instead of the little red one that most come with, and also adding a hood and door sensor will keep them from getting in the car in the first place.)
7 .Clutch Club, (this is a $50 known to stop um tool which is placed on the clutch pedal and disable the ability to shift and start the car.)
8. garage kept, (you can't steal what you can't get to.)
9. GPS, (Tracking of the Car if its stolen could save it)
10. E-Brake Lock. (This is something you can make yourself, by drilling two holes right behinde the e-brake line T. Tap them, then put two bolts that are small enough that they fit under the plastic center cover, and they can't move the car if the e-brake won't go down.)
If you have anything to add, please post and let others know. And if you have your own personal touch feel free to add it, even if its the same as some listed. Sometimes other ways to the same tree bear more fruit!
Old Mar 20, 2009 | 12:13 AM
exz0n-.-'s Avatar
Default Re: Honda Quick Lockdown's*unstealable*
if someone wants your car badly enough they'll get it. ever heard of a flatbed?
it happens
Old Mar 20, 2009 | 12:18 AM
it happens
Note....if you can't hear a flatbed truck around your home. Then your not trying hard enough.
Also this is why you do the e-brake lock. the tires will screech and if you can't hear that, you should be slapped more then once.
also an alarm would go off the second they try to move the car!!!
and final, IF you want your car badly enough you will take a tire with you into your home at night.
and let "them" figure that one out.
Old Mar 20, 2009 | 12:25 AM
****UPDATED****
Using a chain on the rear or front tow hitches and chaining it around a rim or even a fence/basket ball poll or even a anchor that's bolted to the floor will keep them damn thieves at bay. and plus this is something you can do well at the store or school, You may look like a fool by doing this, but you can laugh at the other dumb asses as you drive away in your car that the thieves couldn't steal.
don't forget, some of the biggest blot cutters can only cut locks or chains up to a quarter of an inch thick. Anything bigger and you better be he-man to cut that lock or chain.
Old Mar 20, 2009 | 03:40 AM
CRX Toad's Avatar
Anyone can take anything if they want it bad enough. No matter what you do.
crxblues
Honda Fit
Nov 3, 2012 08:11 PM
hammergunner
Audio / Security / Video
34
Mar 4, 2012 12:10 PM
Tam N
Honda Civic (2006 - 2015)
Feb 24, 2007 10:46 AM
CNS2000
Honda S2000
15
Aug 17, 2005 03:42 PM
H22CL
Jan 12, 2004 04:12 PM
