What ECU for an LSVT ? Kenji ? Any opinions ?
Old Aug 13, 2002 | 06:06 AM
X2BOARD's Avatar
Default What ECU for an LSVT ? Kenji ? Any opinions ?
I have posted some probs before, but it's not doing much good. I am running an LSVT with a B16 head and IM and b18a block. Pistons yeild a 8.97:1 CR
I do not have the K/S in the block, but I did wire it into the ECU at the pin out listed in the helms. I just left the K/S in the cabin, close to the ECU. I wired Vtec as well.. all with 16 gauge wire.
Now the problems start here... I think... I am using a 2000 GSR ECU, obd2. I wired everything in and am only throwing a code 65 (2ndary 02) What happens is that with the GSR ECU, the car feels weaker down low and kinda bogs going into and thru Vtec up to about 6500 rpm, where it opens up some and gets faster. While in vtec, I have to feather the throttle to play with the mixture (that is a total guess) to get ANY kind of power out of vtec. ie: If the idential setups were to race, one with the LS ecu and one with the GSR ecu... the ONLY reason the GSR would win would be because it revs to 8K and makes a MARGINALLY small amount of power between 7K and 8K rpm.
WHY ME ???
I have dicussed this with a couple other people and some suggest the possiblity of the GSR having different fuel maps from an SI ECU, which would cause the tremendous loss of power w/o a GSR dual stage manifold. (I know the ECU does not control the mani). My car REALLY feels like it's holding back ..... even below vtec... but I don't know why...
Any help would be GREAT !
X2
Old Aug 13, 2002 | 06:16 AM
BoM's Avatar
BoM
Default Re: What ECU for an LSVT ? Kenji ? Any opinions ? (X2BOARD)
chipped p28
or
hondata
Old Aug 13, 2002 | 07:23 AM
X2BOARD's Avatar
Default Re: What ECU for an LSVT ? Kenji ? Any opinions ? (BoM)
chipped p28
or
hondata
EeeeeeHHHHH !!! Wrong answer ! Thank you...come again.
I don't really want/need to know about a 'chipped p28, Hondata...blah, blah' I know what those things do.... I need to know why my POS isn't working right.
Old Aug 13, 2002 | 01:36 PM
kenji's Avatar
A GS-R ECU is not the way to go on a single runner intake manifold setup.
About 4 years ago I was running a GS-R ECU with a Field VTEC controller and thought it was working pretty well. I was making about 190 Hp or so. I put in a P28 with a DOHC VTEC program in it and it made a HUGE difference. Especially in the midrange.
Do you feel a lag around 4400 RPM up to about 6000 RPM?
-kenji
Old Aug 13, 2002 | 09:51 PM
gsrteg's Avatar
Default Re: What ECU for an LSVT ? Kenji ? Any opinions ? (kenji)
I am having the exact same prob on my 94 gsr. I have a pr3 head on a b18a block also. Would it be worth just buying some type of chip for my obd1 p72 to illiminate the dual stage fuel curve setup. VTEC is hardly felt or heard with this setup, unless the air is really dense outside, hence, morning or night. then only you can really hear it in 2-3 gears only. thanks, mabey we can work this out together. LOL thanks, daniel
Old Aug 14, 2002 | 02:21 AM
kenji's Avatar
Default Re: What ECU for an LSVT ? Kenji ? Any opinions ? (gsrteg)
gsrteg,
I can chip your P72 to run your setup better. Do you have VTEC/fuel controler?
Email me for more info on chipping your ECU.
-kenji
Old Aug 14, 2002 | 07:43 AM
JeffNA's Avatar
KENJI=
Old Aug 14, 2002 | 08:47 AM
X2BOARD's Avatar
gsrteg,
-kenji
It seems GSRteg and I have identical problems as I can hardly feel vtec in the 4K to 6K range as you had asked. I plan on getting a vafc very soon... would it be necessary for the mod you perform to the chip ? I need one anyway for my fuel setup.
I am gonna assume that the GSR fuel maps below 6500 are different than an SI then ? Does the missing KS affect it at all ?
Kenji, can you also eliminate the obd2 (2ndary 02) feature from an obd2 GSR ecu when you chip it ?
Also, would I be able to use the same chip when I reinstall my turbo ?
X2
[Modified by X2BOARD, 12:48 PM 8/14/2002]
Old Aug 14, 2002 | 09:13 AM
kenji's Avatar
X2BOARD,
Unfortunately, I can not chip OBD2 ECUs...yet. I was under the impression that you had an OBD1 ECU.
If you want to stick with an OBD2 ECU there are some people who can chip it. If you want to switch to OBD1 I can chip that ECU.
Let me know. Either way I will be happy to help you out.
-kenji
Old Aug 14, 2002 | 09:25 AM
X2BOARD's Avatar
Kewl... thanks for the feed back... it has helped... my budget is pretty shot right now will all the work that was done and still needs to be, but I will need a good ECU for the daily driver for now. Would a P28 plug directly to my harness ? Or will I need the conversion harness ? 2 to 1 ? I am contemplating switching to an OBDI, but that's kinda costly with a harness and new ecu.
X2
Old Aug 15, 2002 | 08:49 AM
gsrteg's Avatar
what car does a p91 ecu come out of? Is the ecu for 2 stage intakes? just wondering
Old Aug 15, 2002 | 09:56 AM
eg6ajk's Avatar
p91 = JDM civic coupe (d16a (sohc vtec ecu)), it comes always in auto form, basically our auto P28 but minus the athmospheric pressure sensor
Old Aug 15, 2002 | 10:38 AM
X2BOARD's Avatar
Default Re: What ECU for an LSVT ? Kenji ? Any opinions ? (eg6ajk)
I am gonna take a shot in the dark and say that the p28 base fuel map is nowhere near what a GSR or GSVT would need, right ?
Old Aug 15, 2002 | 04:35 PM
gsrteg's Avatar
Kenji Do you have VTEC/fuel controler?
No, I don't have a vtec controller. But I might buy a jdm p30 to try and fix my probs. hopefully
nk cs
11
Aug 6, 2008 03:25 PM
poormans_typer69
Dec 24, 2006 05:46 PM
JBirch_97Prelude
Jun 29, 2006 03:29 PM
milano2kdc2
Jul 3, 2003 05:01 PM
sk8phaze
May 19, 2003 11:14 AM
