vtec wiring
i swapped a b16a2 from an em1 into an ej8, im using the p2t ecu with the wiring harness off the b16. the car i swapped it into didnt have vtec, and i was wondering if i had to phisically wire up for vtec. ive seen threads on here with the exact pinouts on the ecu, but i couldnt find any. could someone plz post up the link. thnx
yes you have to physically wire the vtec IF your engine harness came from a non vtec motor.. meaning using a separate wire line and wiring that directly to the ecu.. if its a jdm ecu then only the vtec solenoid needs to be wired. If its a usdm ecu then the vtec pressure switch and the vtec solenoid needs to be wired..
96-98 civic = http://www.phearable.net/tech/wiring/wiring.96-98_2.jpg
99-00 civic = http://www.phearable.net/tech/wiring/wiring.99-01_2.jpg
if you already have a engine harness that came out of a vtec motor then you dont have to worry about wiring it.. unless you have a jdm engine and running a usdm ecu then the CEL will come on for VTPS or vtec pressure switch because the jdm engines dont use VTPS.. theres also a trick to bypass this method..
http://www.phearable.net/tech/wiring/vtpsbypass.gif
you cant tell on yours? any check engine lights? is your speedo working? put it on second gear and hold it until around 5000rpms and see if you hear a difference.
Bingo! thats your problem. Vtec doesnt work if your speedo isnt working. Besides you dont have a VSS thus your speedo isnt working. You need to find a VSS asap and THEN vtec will work I guaranteed it!
To further explain, VTEC won't engage if you are below a certain speed. Since your VSS is missing or whatever, the ECU doesn't know how fast you are going and thus VTEC won't engage.
