question about sanding valve cover
hey i just bought a valve cover thats powder coated wrinkle red like a type r. its never been mounted after the paint work. i wanted to know whats the best grit and sand paper to sand of the letters as they painted it completely. or should i just leave it painted?
use 300-400 grit first... then 600 grit.. then 1000 grit should smooth it.. or you can use a smooth filer at first and file the letters because that wrinkle paint is really thick.. then 400 grit, 600 grit, and finally 1000 grit but its not necessary.. then you can top it off by using mothers aluminum polish wax.. it worked for me..
94c1v1cex
May 20, 2007 07:11 PM
