identify prop valves
Old Mar 19, 2009 | 06:57 PM
PhrequenC's Avatar
Default identify prop valves
is there anything on a 99-00 prop valve to identify if its 4040(si) or 6040(ex)
Old Mar 19, 2009 | 07:31 PM
tdbhonda's Avatar
Default Re: identify prop valves
if i think of it.. i have an hx and a wrecked si
ill look at them both and see if there is a significant difference
Old Mar 19, 2009 | 07:34 PM
tdbhonda's Avatar
here is the SI
i dont know if this will help
do they look the same?
Old Mar 19, 2009 | 08:18 PM
SOHCNightmare's Avatar
i believe the DX prop valve is a 4030 (or 3040) cant remember which order Its been a while since i swapped mine out. I know the Si and Da integra use the 4040 with the rear disc.
Old Mar 20, 2009 | 03:44 AM
94EG8's Avatar
Seagull Management
I'm not sure about '96 - '00 prop valves as they are completely difference externally than '92 - '95 Civic/'94 - '01 Integra versions , but earlier prop valves have a numbers like 3030, 3040 and 4040 stamped on the body of the valve. The '99 - '00 Si uses the same prop valve as the '96 - '00 CX/DX hatchbacks btw.
Old Mar 20, 2009 | 05:38 AM
PhrequenC's Avatar
i know that the 96-00 prop all look the same, but they aren't stamped with a number or such to identify them?
Old Mar 23, 2009 | 02:14 PM
PhrequenC's Avatar
Old Mar 25, 2009 | 01:09 PM
PhrequenC's Avatar
nobody?
Old Mar 25, 2009 | 01:41 PM
94EG8's Avatar
Seagull Management
You'll have to look at one and see. Just check the one thats in your civic now, I know on the 5th gens and integras you can see it without removing it, it is difficult to see though.
Old Mar 25, 2009 | 05:17 PM
PhrequenC's Avatar
im trying to buy one online and the kid doesnt know if its a 4040 or not. i dont see any specific markings on mine, or the pics (which are high res) to see
Old Mar 25, 2009 | 05:51 PM
91blackEF's Avatar
no when you put the two together there is no knowing which one is which it sucks i know i almost mot mine mixed up before when i was swapping it out but mine have a little black overspray on it thank god..
Old Mar 28, 2009 | 05:45 PM
PhrequenC's Avatar
ttt
Old Mar 28, 2009 | 05:57 PM
Meoshe's Avatar
96-00 hatchbacks and hx's are the same as si.
Old Mar 29, 2009 | 08:20 AM
PhrequenC's Avatar
no sir they are not. dif part numbers for one.. but ex, ls, vx, hx, cx whatever they are arent 4040 distrobution only si is bc of rear disk brakes
Old Mar 29, 2009 | 12:59 PM
94EG8's Avatar
Seagull Management
correct
All '96 - '00 Civic hatchbacks, and HX and Si coupes share the same prop valve, same part number
95EG2
Aug 22, 2010 09:10 AM
blinx9900
Suspension & Brakes
Jun 7, 2007 10:20 AM
Mr. Choi
Jun 21, 2004 11:49 AM
Jonathan_ED3
Mar 24, 2004 02:50 PM
