Alternator Fitment With B Series
Old Mar 19, 2009 | 06:37 PM
streetsold6teeny8's Avatar
Default Alternator Fitment With B Series
Can someone please send me a picture of where exactly you bang in the engine bay to fit a b series... I think i banged in the right spot not sure tho... i banged under the shock tower on the drivers side and under that little hole thats under the tower.. I need ot know since my cars at the shop getting painted...my fault to not look up b4... Thanks guys
Old Mar 19, 2009 | 07:08 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: pic request regarding banging to fit b series
mine:
Old Mar 19, 2009 | 07:31 PM
D16SiHatch's Avatar
^yea that about takes care of it lol, but heres some other angles with the engine installed..
Old Mar 19, 2009 | 08:47 PM
D16SiHatch's Avatar
why would you need to bang there. i've never heard of crank pulley clearance there being an issue, nor did i have an issue there with my ls swap. my pulley did hit the radius rod though due to how low my car sits, but that was another issue which i solved by getting a ctr pulley. the only thing you need to make clearance for is the alternator.
Old Mar 20, 2009 | 07:43 AM
SC_HOBD_1816's Avatar
sorry it was later last night i couldn't see where my cousin banged it at. my cousin did swapped for me he told me he had to do a clearance for the alternator belt so it will be easy to repair later down the line. Checked this morning and the place is by the Alternator. Your right D16Si. Other post will be delete for misinformation.
Old Mar 20, 2009 | 08:41 AM
jhammond_82's Avatar
Reject Papi
so the japanese bang on the civic before putting the stock b16 in them? i don't get it. i've seen lots of b series swaps in ef's and never saw a clearance issue either. more info please... i'm getting ready to swap an ls myself, and would like to know before i beat the **** out of my car if its really necessary.
Old Mar 20, 2009 | 08:58 AM
D16SiHatch's Avatar
it is really necessary. either the chassis in the ef9 is different, or possibly the mounts change the location of the engine slightly so that its not a problem. either way i can tell you with first hand experience doing an ls swap that you absolutely have to do this for clearance.
Old Mar 20, 2009 | 11:45 AM
northemt88's Avatar
x2 in my experience you have to dent, didnt do it on one of my friend and we hand a bitch of a time to make it fit and forget about changing alt belts if you dont
Old Mar 20, 2009 | 11:49 AM
Furyof4's Avatar
Honda originally positioned the b16 in the ef9 farther forward than most aftermarket mount kits do in our chassis.
Old Mar 20, 2009 | 12:48 PM
dohc_star's Avatar
also the jdm crx mite have diffrent bracing for the brake booster and clutch pedal mabey i dont know just a thought
Old Mar 20, 2009 | 01:50 PM
EJ1_Sleeper's Avatar
ah cant wait to take the 5lb sledge to it. im also removing the power steering rib of the crank pulley, i herd using a smaller alt belt helps alot too.
Old Mar 20, 2009 | 01:58 PM
ALLxMOTOR EG's Avatar
Vietnamese!
It's time for bang bang bang.
Old Mar 20, 2009 | 02:03 PM
I have no idea if it would fit without banging it. my cousin just did for me and told me it would be for access to the alternator belt. It might fit well but when it comes time for a new alternator belt good luck. start banging, LoL.
Old Mar 20, 2009 | 05:43 PM
Thanks guys for the replies... I did bang there SO i banged right... and whats this about crank puller hitting the radius arms??
Old Mar 20, 2009 | 06:08 PM
Cole89ef's Avatar
Default Re: Alternator Fitment With B Series
By the time I needed to swap in my B16A I was ready to hit the car. Don't forget about the front motor mount bracket.
Old Mar 20, 2009 | 06:19 PM
D16SiHatch's Avatar
Originally Posted by streetsold6teeny8
Thanks guys for the replies... I did bang there SO i banged right... and whats this about crank pulley hitting the radius arms??
if your car is lowered like mine... then you will likely run into trouble. it grinded against the radius bar whenever making right turns.
these pics are with the car jacked up in the air btw
Old Mar 20, 2009 | 10:01 PM
ef_b18a1's Avatar
what ever you do, do not get 4-1 headers... where it wraps 4 pipes down and around to 1 pipe near your cat................ i had to raise my car up soooo much so i wouldnt scrape and still scraped... but to who ever said,
"""so the japanese bang on the civic before putting the stock b16 in them? i don't get it. i've seen lots of b series swaps in ef's and never saw a clearance issue either"""
what i did when i bashed that inner wall was i took a grinder too it... smoothed it out some then took a sanding grinding wheel, and made it so it took all the rough edges and uneveness of my bash marks... grabbed spray paint and painted it... you cant even tell..
but if you do decide to get the 4-1 headers you have to beat the living **** out of your front cross bar, that held your front tranny mount for your d series... http://www.jhpusa.com/store/pc/catal...b.header_d.jpg
you know what scratch that... dont even think about buying them!!!!!!!!!!!!!!!
Old Mar 21, 2009 | 07:32 AM
01-0041's Avatar
Just a quick shot of what I did...
Notes:
- CTR N1 pulley
- 292 Belt
[img]https://lh4.ggpht.com/_MDj61SXbZz4/SaTvNqo1p9I/AAAAAAAABJc/-pBvV2ft8MI/s800/DSC01761.JPG[/img
Canadian_EF
Apr 3, 2014 08:18 PM
bbrian
Mar 6, 2006 09:36 PM
Audipwr1
May 14, 2003 05:41 PM
Audipwr1
May 14, 2003 08:13 AM
bumpin_bass
Oct 4, 2002 12:30 PM
