b16a2 into 96 dx hatch: obd2a-obd2b question
so, as the title states, im going to be preforming my first swap soon on my little hatch. i just have a question about the wiring, i understand that obd2 is undesirable to everyone on here.. but reason being im keeping it obd2 is because i want to get it BAR'd since i live in california, i also know that everyone says b16's suck and without vtec its the same as a d16 blah blah blah.. but back to my situation.. so my car is obd2a of course, and the motor/harness/ecu is obd2b so i have the original uncut si harness, and p2t ecu, and my question was can i just repin the ecu wires so they go where theyre supposed to, or is there more to it than that? ive went over different wiring pinouts and diagrams and i have a helms to refer to, but i wanted to ask because maybe someone has first hand experience with this swap.. maybe after i get it to pass BAR i will convert to obd1 and run a chipped p28 like everyone else, but for now i need to wire it up as if it were an EM1 from my understanding of how the state ref. works.
if anyone has any suggestions, or knows something i dont, please share.. its my first swap, and i would like for it to go as smoothly as possible.. its my first car, and daily so i cant be without it too long.
Thanks,
Steve.
Thanks,
Steve.
if u got the 99-00 complete engine harness then no need to repin/cut anything...its a straight plugs and play and u dont eve need a jumper harness for the ecu..wire up the motor if its already out of the car,drop it in, hook everything up and plug in the ecu
if u wanna pass Bar u need a cat thats from a 99-00 SI
ALL evap parts hooked up correctly and working properly
ALL readiness monitors set to Ready/Complete
so the motor will be plug and play even though its 2a/2b?
i have the cat, and alll the parts out of the si, evap stuff, sensors, everything.
if i got that off the si, could i add it into my hatch?
dang, everyday this 'little' project is becoming more and more of a problem.
Thank you both for your help.
u said that u had the complete engine harness off the 99-00 SI? if so its a plug and play cuz the engine harness and a whole 1 piece design wit the ecu plugs at the end of it so no need to cut and splice anything
here is a link about the Fuel Tank Pressure sensor if u run into that problem
http://technet.ff-squad.com/code91.htm
this is what the interior side of my harness looks like, this is why its confusing me.. aren't there supposed to be 3 plugs?
Thanks,
Steve.
Thanks,
Steve.
To the OP, if you can get away with the OBD2a to OBD2b conversion harness do it. If not, get ready to start depinning / repinning. That state sucks when it comes to REF/BARd. You will need to get all the OBD2b emissions stuff....fuel tank, stuff, etc. from what I remember. Some people get lucky...others have to go the hard route.
Negative. The 96-98 and 99-00 harnesses are not interchangable. The 96-98 has all three ecu plugs on the engine harness. The 99-00 does not have all of them....in fact the A plug is on the under dash for the 99-00 harness.
Buy the ETM from Helm and start depinning / repinning. The OBD2 pins come out super easy. I would pick up another set of empty plugs so you can depin and then repin into the new connectors....instead of trying to depin all the pins, lose track, etc. I can sell you a set of empty new connectors if you need them. Might as well buy a few new pins too in case you murder some on removal.
geneeunit
Mar 19, 2009 08:04 PM
ekhatch08
13
May 26, 2008 04:58 PM
Patrickchampagne2006
Mar 29, 2007 04:57 PM
