Launching at the track
Old Aug 13, 2002 | 05:28 AM
CarbonfiberR's Avatar
Default Launching at the track
At what rpm's do you guys with the azenis's launch at when your at the track? I was dumping the clutch a 5000 and the tires would not spin, just grip and the car would bog.
Old Aug 13, 2002 | 05:37 AM
MPH's Avatar
MPH
New User
Default Re: Launching at the track (CarbonfiberR)
Feather clutch instead of dumping
Old Aug 13, 2002 | 05:47 AM
sackdz's Avatar
If the tires aren't spinning then launch at a higher rpm until they do.
Old Aug 13, 2002 | 08:32 AM
Default Re: Launching at the track (sackdz)
I tried feathering the clutch but that didnt work and I didnt want to launch that high in fear of breaking something. But I guess I will try higher rpms next time. Also I was running the tires with 34 psi, is that too much?
[Modified by CarbonfiberR, 12:33 PM 8/13/2002]
Old Aug 13, 2002 | 08:36 AM
RTW DC2R's Avatar
you dont want to spin off the launch. spinning = slower times
practice feathering the clutch from higher rpm without spinning and you will get nice launches, however your clutch will hate you.
Old Aug 13, 2002 | 08:40 AM
sackdz's Avatar
Yes 34 is too much. General idea is to have the softest sidewall possible and lowering pressure to 20 and below should help noticably.
I'm no drag racer, but I think the ideal rpm is between that which your never bogs, and you are able to modualte the clutch to have no wheelhop or excess spin.
HTH
Old Aug 13, 2002 | 09:59 AM
RiCE On IcE 2's Avatar
feathering as in?
Old Aug 13, 2002 | 11:21 AM
Tommy_Gunns's Avatar
Wow...the Azenis are that sticky?
Old Aug 13, 2002 | 03:55 PM
uncleben's Avatar
check out the thread i started a few days ago after a trip to the drag strip... i got some pretty good info:
https://honda-tech.com/zerothread?id=250066
Old Aug 13, 2002 | 05:20 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Your clutch must be going out because a 5k dump with Azenis should spin no problem unless the track was soaked with traction compound.
Old Aug 13, 2002 | 05:47 PM
4-1-1's Avatar
Default Re: Launching at the track (ActiveAero Ninja Edition)
Without the R wing, your car turns into a sohc nonvtec motor
Old Aug 13, 2002 | 07:06 PM
Default Re: Launching at the track (4-1-1)
The track people were taking real good care of the track. They cleaned it and added vht alot during the four hours I was there. Plus there were only 30 cars running. I have about 30000 miles on my car so the clutch might be going.
Old Aug 13, 2002 | 07:50 PM
Driver's Avatar
Front tire pressure to + / - 25 psi and feathered clutch at around 6000 rpm.
Old Aug 13, 2002 | 08:18 PM
SoCal ITR's Avatar
Default Re: Launching at the track (01-1214)
I'd say drop the pressure to sub 20, maybe down to 17 or 18, and don't drop it but barely feather it from 5500-6000 rpm.
Old Aug 14, 2002 | 06:35 AM
GM2000ITR's Avatar
New User
Default Re: Launching at the track (SoCal ITR)
Agreed! Dropping the clutch (at, say, 6000rpm or so) will result in this: ...ouch!!!!!
Old Aug 14, 2002 | 08:19 AM
Default Re: Launching at the track (GM2000ITR)
Breaking an axle is exactly what I dont want to happen.
Old Aug 14, 2002 | 08:27 AM
RTW DC2R's Avatar
Competition engineering or Driveshaftshop
Old Aug 15, 2002 | 04:12 AM
Default Re: Launching at the track (RTW DC2)
Why bring down the tire pressure if I am already getting enough traction? Or is there another reason for bringing down the tire pressure?
Old Aug 15, 2002 | 04:19 AM
icefire069's Avatar
Hey Alex that is why you feather it out of 3k and just step on it. At 3k you wont bog out too much.
Sorry for not calling man. I've been busy. I'll call you later this evening to get my helmet back. LOLOL.
Old Aug 15, 2002 | 05:53 AM
Default Re: Launching at the track (icefire069)
Helmet? What helmet?
Old Aug 15, 2002 | 05:56 AM
E. Honda's Avatar
Whuts feathering? Please educate
Old Aug 15, 2002 | 08:27 AM
Keyed ITR's Avatar
Default Re: Launching at the track (CDM SiR)
What exactly is entailed in a good aftermarket driveshaft? I certainly don't want to get a new clutch and beat the **** out of it, knowing that the driveshaft holds an equal amount of stress.
Old Aug 15, 2002 | 08:37 AM
SoCal ITR's Avatar
Dropping the pressure gives you more traction, so you can launch at a higher rpm without spin.
Old Aug 15, 2002 | 09:00 AM
Mr Hammond's Avatar
a/k/a Jomo
Azenis can like alot of pressure. Max PSI is 51. Drop them down to sub 20 or even below 30 and i think you'll be scooping out rubber by the shovel full from inside those things. I'd be very carefull. Why not just sell em and get some ET Drag's or if you are lazy NT555R's.
Later.
Old Aug 15, 2002 | 10:20 AM
Got-VTEC's Avatar
New User
What were you 60 ft times?
That will help to see if you are getting a proper launch.
