Wot issue?!?! Cant smash the throttle!!! Why?
Old Mar 19, 2009 | 11:48 AM
LSXFEIND's Avatar
Default Wot issue?!?! Cant smash the throttle!!! Why?
alright guys heres my problem NOW i put a mini me with a y8 head in my EF converted a bunch of ****, it will pull and hit Vtec Pretty good at about 70% of the throttle but when i floor it..it bogs out!! WHY??
Old Mar 19, 2009 | 05:15 PM
ih8sndq's Avatar
Default Re: Wot issue?!?! Cant smash the throttle!!! Why?
Is your TPS wired up correctly?
Old Mar 19, 2009 | 05:39 PM
~sp33~'s Avatar
EFB055
Timing?...
Old Mar 19, 2009 | 05:41 PM
boostedefhatch's Avatar
Originally Posted by ~sp33~
Timing?...
he ALWAYS says that even on my thread, but he was right, :D my timing was off my car bogged bad when i floored it, make sure ur timing ir sight the crank pulley set to tdc and check and see if ur cam is at tdc if its not that is prolly ur problem, easy fix
Old Mar 19, 2009 | 05:58 PM
89s1's Avatar
lol yeah, i can see why he says it too. A motor is a pretty basic thing when you think about it.
It's just a big air pump with fuel injected into it then lit on fire.
if you have fuel and spark, then look into the timing of everything.
Old Mar 19, 2009 | 05:59 PM
^ what he said lol
Old Mar 19, 2009 | 07:10 PM
~sp33~'s Avatar
EFB055
I do, usually because that's the easiest thing to F*** up, and for some reason the most overlooked.
Old Mar 19, 2009 | 07:27 PM
sixgunsound's Avatar
Turbo lag y0
Old Mar 19, 2009 | 11:04 PM
LSXFEIND's Avatar
thanks everybody, somebody told me to change my spark plug wires ??? but i got spark lol
Old Mar 20, 2009 | 04:18 AM
ef-hatchcrap's Avatar
switch the 2 outside tps wires around and see what that does
Old Mar 20, 2009 | 07:21 AM
LSXFEIND's Avatar
ok ill give it a shot but do i just pry um out?
Old Mar 20, 2009 | 03:29 PM
gringo7718's Avatar
Sounds like a weak ignition problem or a timing problem. As you increase load, the injectors spray more fuel but a weak ignition system cannot ignite the mixture or the timing is off and not igniting the mixture at the right time.
Look at distributor/coil, cap, rotor, wires, and plugs.
Check ignition timing with a timing light
Here is the TPS wiring. Verify that you are getting the proper voltage to the correct locations.
dthurlow79
Classic Hondas
11
Jan 28, 2015 10:18 PM
mruhl4@cox.net
Classic Hondas
Aug 27, 2008 08:36 PM
blaxican05
Sep 29, 2006 08:23 PM
migs
11
Dec 30, 2005 10:51 PM
TURBODEEZ
Oct 11, 2005 02:38 PM
