Honda S2000 Honda S2000
Spuddering problems?
Old Mar 18, 2009 | 07:58 PM
hondanc7's Avatar
Default Spuddering problems?
Ok so I have a 2001 S2k. Im having this problem where once the car gets warm, and you rev up, when the rpm's drop, the drop so low the car wants to stall out pretty much and you can feel it. It does it when you crank the car too, like on a warm crank, it will rev up then drop back down real low, spudder real bad then catch back up to around 900 rpm's. The spark plugs are new and all the coil packs are new btw. Any ideas? Ive hit the MAP sensor before, seemed to help for like 3 days, but not 100% sure if that was the problem.
Old Mar 19, 2009 | 06:33 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Spuddering problems?
Have you tried adjusting the idle per the FSM?
Old Mar 19, 2009 | 12:00 PM
bigmacnfries's Avatar
could a dirty map sensor give these symptoms - might be worth a second look?
Old Mar 19, 2009 | 02:10 PM
AP1_man's Avatar
^^^yes
one thing i can think of is to disconnect the map sensor, clean the plug s with electrical cleaner, reattach it after its dry, make sure all the screws are tight. also you can put zipties around the map sensor to ensure its not loose.
i know there is a how-to out there floating around the intra-webs
bigempty12
Sep 13, 2007 03:42 PM
xASAPx
Sep 15, 2006 09:21 PM
dizzyek
May 17, 2006 09:38 AM
GQ 05YellowEVO8
Jul 12, 2001 09:23 AM
