will this pass smog?
Old Mar 18, 2009 | 07:44 PM
LB98ekhatch's Avatar
Banned
Icon3 will this pass smog?
so my valves ran into my pistons so im replacing the whole head.
i have a 96 civic with a stock sohc vtec y8
i'm buying from a friend a 95 z6 sohc vtec head, i'll run my distributor from my y8.
heres the main thing, the z6 comes with supertech valvesprings and retainers running STOCK camshaft.
will it pass smog? (CA state emissions)
Old Mar 18, 2009 | 08:03 PM
cmc600rr's Avatar
Default Re: will this pass smog?
I dunno if this matters but I thought any engine modification like heads or the block or the entire motor had to me the model year or newer.
Old Mar 18, 2009 | 11:16 PM
Banned
asdf
Old Mar 18, 2009 | 11:18 PM
john666's Avatar
i believe it should as long as all your smog stuff is still there.. ( cat)
Old Mar 19, 2009 | 09:38 AM
Banned
anyone else?
Old Mar 19, 2009 | 11:51 AM
Banned
damn hondatech succs now, no help at all
Old Mar 19, 2009 | 12:01 PM
dividedas1's Avatar
im willing to bet if they realize its an older head you will fail :/ but then again idk about cali laws. its a little bit more easier here in iLL to pass emissions (no emissions required for odb1 cars)
Old Mar 19, 2009 | 12:04 PM
teamworxek9's Avatar
valvetrain shouldn't make you car fail smog.
Old Mar 19, 2009 | 01:27 PM
94EG8's Avatar
Seagull Management
He's swapping the whole head though, which happens to be where the date code is stamped.
Old Mar 19, 2009 | 05:59 PM
sir2ya's Avatar
I will be helpful and say IDK...
Old Mar 19, 2009 | 06:09 PM
Banned
thanks alot...
Old Mar 19, 2009 | 06:49 PM
but just swaping a head i wouldnt think they would look at the date codes.
Old Mar 19, 2009 | 06:58 PM
24TEN's Avatar
PHANTOM MENACE
I couldn't say yes or no to the original question BUT I can point out a couple of key things that could possibly effect your smog outcome.
Visually, it would fail IF and ONLY IF they notice the head is incorrect. It is true that the motor of the car has to be the same year or newer but a replacement head swap is sort of a gray area. If the tech is knowledgeable and looks for that sort of thing then yeah, you have a good chance of failing visual (but maybe the tech won't care who knows).
For emissions I couldn't see aftermarket valve springs having a negative impact on your emissions but the thing is that the Z6 head has a higher volume combustion chamber than your Y8 head does. Having said that, your compression ration should actually go down. That's what you really have to worry about. If I'm not mistaken, my buddy (who is a smog tech) told me that lowering compression shouldn't hurt.
If you want some actual hard info, hit "thesmogman" on here. He's very helpful and knowledgeable with this type of stuff...obviously because it's his profession
Old Mar 19, 2009 | 09:01 PM
Banned
well i found another head, its light port & polished. if i dont want to go trough the stress with the z6 head i minus well get this y8.
pics:
http://jase-ace.com/public/photo/For...0Head%2001.jpg
http://jase-ace.com/public/photo/For...0Head%2002.jpg
sireg6
Oct 17, 2007 11:22 AM
vietnameeh
Jun 21, 2005 01:35 PM
96tegsr
Jul 23, 2003 02:43 PM
alphaquake
Apr 23, 2002 11:26 AM
