Can I use a USDM p72 with B18c
Hello all,
I just purchased an OBD1 JDM GSR longblock and was wondering if it would be ok to run a USDM OBD1 p72 ecu with it. I know there is a slight difference in compression between the 2 motors but I am unable to find a JDM p72 but see a few US ecu's for sale. Will the difference from 10.0 to 10.6 make a huge difference requiring me to use the JDM ecu?
I appreciate any feedback.
Thanks
Thanks
You should be fine with the USDM ecu
If you want an JDM GSR ecu I have one, its OBD2 but I have a conversion harness with it also. Just shoot me a PM if your interested
I found these
http://www.b18c5eg.com/EcuDefinitionCodes/
there CROME files of both stock USDM & JDM P72 Bin's, but I'm not sure of the authenticity and I'm not a tuner.
USDM lowcam ignition
JDM lowcam ignition
USDM highcam ignition
JDM highcam ignition
USDM lowcam fuel
JDM lowcam fuel
USDM highcam fuel
JDM highcam fuel
JDM lowcam ignition
USDM lowcam fuel
JDM lowcam fuel
USDM highcam fuel
JDM highcam fuel
It's very difficult to compare the maps directly, keep in mind that the stock tables are tuned to run on different fuel. And a lot of their modifiers are slightly different as well. (the fine tuning for ECT, IAT, etc)
Conclusion, the USDM P72 will run the JDM GSR fine.
I've done it before.
