Brake light always on??????
Old Mar 18, 2009 | 06:46 PM
FOMULA91's Avatar
Default Brake light always on??????
My car alarm went off right now and I don’t see anyone around it to I went outside to go check it out. What I found out was my brake light was on???? I was like WTF and tried to crank it up but the batter was dead. I have the back up batter for my car so the alarm still works but the actual battery is getting drain from the brake lamp being always on. I’ve been driving my CRX all day and this happen all of suddenly. Its already dark and I cant check it out til tomorrow and I have MID term tomorrow morning. Thank God I only live like a 2 mile away from school but this sucks….. Any suggestion?
Old Mar 18, 2009 | 06:59 PM
grog's Avatar
Default Re: Brake light always on??????
there should be a small crumbled piece of plastic on your floor. you need to replace that plug which is located on a tab on the brake pedal ,its next to the brake light switch . or look in the FAQS page for pictures.
you can rig it up to work with a penny and some glue, until you get a new plug from the dealer.
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
It's a common problem
little rubber piece that hits the switch under the dash..
Old Mar 18, 2009 | 07:06 PM
jhammond_82's Avatar
Reject Papi
makes you wish there were 24 hour part stores huh?
FOMULA91's Avatar
Thanks for the fast response. Will fix it tomorrow after mid-term......
Old Mar 18, 2009 | 07:09 PM
FOMULA91's Avatar
Also, do I have to replace the whole brake switch or just the rubber piece?
Old Mar 18, 2009 | 07:13 PM
sinepome's Avatar
just the rubber piece.
you can just use a bolt and nut.
that's what i did.
GL
Old Mar 18, 2009 | 07:14 PM
dr_latino999's Avatar
Even better, I once used a penny and some tape to stop myself from going crazy on a long trip.
Old Mar 18, 2009 | 07:16 PM
FOMULA91's Avatar
LOL serious?
Old Mar 18, 2009 | 07:17 PM
88DXCRX's Avatar
that's what i did.
GL
That is a 5/16" bolt in the picture above..
Old Mar 18, 2009 | 07:19 PM
Originally Posted by FOMULA91
LOL serious?
Serious, and then the best part was that I forgot it was there until two years later when it fell back off. Spent some time figuring out where the penny came from until I noticed my lights were back, finally replaced the stopper. Hardest dollar I've ever parted with j/k.
Old Mar 18, 2009 | 07:22 PM
crxtasy1234's Avatar
New User
check the brake switch under the brake pedal
Old Mar 18, 2009 | 07:27 PM
88DXCRX's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/brake-lights-dont-turn-off-2094313/
Old Mar 18, 2009 | 07:42 PM
FOMULA91's Avatar
Yeah just went back to take out the battery so I can charge it and found the plastic blue piece in 3 pieces. Thanks for the help guys
so the 5/16 bolt just screw right it?
Old Mar 18, 2009 | 07:43 PM
88DXCRX's Avatar
Where the plastic piece fell out is an open hole,
Push the pedal in and stick the bolt in the hole..
1/4" to 1/2" long bolt should work
Nonio
May 8, 2014 05:39 AM
dderolph
Jan 10, 2013 12:34 PM
tegguy
Dec 10, 2011 05:43 AM
jdmdc2boi12
Honda Motorcycles
Jul 18, 2009 07:37 PM
Andrea_Aunie
Oct 20, 2001 11:46 AM
