Check Engine
Old Mar 18, 2009 | 06:07 PM
jdavis94teg's Avatar
Icon2 Check Engine
Just got ahold of my EF today. I drove it yesterday before I made the money transfer and it ran fine. Today, as I was heading home from the pick-up, the check engine light came on. I knew that i had to replace the fuel pump relay, thought that woulda been the cause. I changed it, it didnt come on when i turned the car over, but as I was driving, it came on again. time after time, it would turn on during the time i was driving. the car hasnt been used in a while, and is in need of an oil change, but i wouldn't think that would set off the light? when it first came on heading home from the pick-up, we had to put stored gasoline in it to get it to a gas station, thought maybe because it was old fuel and just had to burn through it to get to the premium. does anyone have any suggestions? it continues to drive fine I just wanna idea of what the diagnostic is.
Old Mar 18, 2009 | 06:31 PM
91DBSexyTime's Avatar
Default Re: Check Engine
did you count the flashes from the LED on the ecu? thats the only way you are going to figure it out.
Old Mar 18, 2009 | 06:36 PM
.. no? how do i do that
Old Mar 18, 2009 | 06:42 PM
on the passenger side pull the carpet forward and you will see a metal cover with a hole in the middle which the ecu is behind, if there is a CEL while the car is running it will flash a certain number of times indicating what the problem is.
Old Mar 18, 2009 | 06:44 PM
heres a link the rywire.com explaining it and the codes http://rywire.com/store/faqdesk_info...6e410182f6c602
Old Mar 19, 2009 | 12:42 PM
thanks man
Old Mar 19, 2009 | 01:46 PM
it blinked once, which according to the link you gave me is o2, does this mean i need to replace an o2 sensor?
Old Mar 22, 2009 | 11:27 PM
Yeah I would, double check wiring also first then reset the ecu
Old Mar 23, 2009 | 08:53 AM
i did all that, it still comes on, im thinkin it's the m.a.p sensor now
Old Mar 24, 2009 | 08:49 AM
bump!
tryin to figure this out, not tryin to spend 165 on a m.a.p sensor if i dont need to!
Old Mar 24, 2009 | 11:07 AM
jlicrx's Avatar
why do you think it is the MAP sensor? - if it blinks once, the problem is with the Oxygen Sensor - just replace it - not very expensive
http://shop.advanceautoparts.com/web...S_614213344___
Mr_Accord92
Nov 5, 2010 09:31 PM
Teamdiesel
May 18, 2007 05:57 AM
legends
Jun 8, 2006 08:36 PM
b16_madman
12
Apr 17, 2003 05:39 AM
pcorad
May 15, 2002 04:50 AM
