Wiring a DEI 507M to a Compustar alarm
Hey guys, i recently installed a Compustar Alarm with a CM 4300 alarm module, I want to buy and install a DEi 507M tilt sensor for my self. The 507M wire harness has 3 wires out of it and the optional sensor input port on the alarm is a four pin, how should i hook this up?
These are the wires for each component i want to add at for the alarm brain, I read that for the ground when alarm is armed to tap into testarter output on CN1 that goes to the starter kill relay on the alarm brain
Compustar CM 4300:
Pin 1 Black – Negative (-) ground.
Pin 2 Black/White - 2nd stage negative (-) input. (Instant trigger)
Pin 3 Red – 12V positive (+) output.
Pin 4 Grey/White - 1st stage negative (-) input. (Warn away)
CrimeGaurd AU94T:
Red wire connects to 12V constant power
Black wire connects to ground (or neg. while armed output on an alarm)
Blue wire is the main negative trigger output
Green wire is a pre-warning negative trigger output
DEI 507M:
RED (+)12V Constant: Connect this wire to a (+)12V constant power source.
ORANGE (-) Turn-on Input: Connect this wire to the (-) ground-when-armed output of the vehicle securitysystem. If the security system does not provide a (-) ground-when-armed output. An alternative solution is toconnect this wire to the true ignition wire of the vehicle (this wire must rest at ground when the ignition key
is in the OFF position).
IMPORTANT! In order for the 507M to learn the inclination angle each time the vehicle is
parked, the ORANGE wire must be connected to a security system ground-when-armed output orto an acceptable switched ignition ground reference wire.
BLUE (-) Trigger Output: Connect this wire to the instant trigger input of the vehicle security system.
Compustar CM 4300:
CrimeGaurd AU94T:
DEI 507M:
Unjockable
Audio / Security / Video
Mar 8, 2005 12:06 PM
