using integra sway bars
Old Mar 18, 2009 | 03:20 PM
ej1love's Avatar
Default using integra sway bars
hi i just found a 96 integra 4-door in the junkyard and was wondering if those lca's are the same as the integra 2-door? Essentially i'm askin if they will work on my 95 coupe? i know the 2-door teg does no problems... any difference with the 4-door? it has a stock rear swaybar, do all integras come with one? cause idk if it was a gs-r.
Old Mar 18, 2009 | 03:22 PM
casper007's Avatar
Default Re: using integra sway bars
I think they do. The easiest way to confirm is to check part numbers with Acura dealer to see if the 2door and 4 door are the same.
Old Mar 18, 2009 | 03:24 PM
ej1love's Avatar
well they want 25$ for rear lca's and the sway... lol, im getting them regardless i just read the 4-door is 14mm rear, the same as a gs-r. so the lca's should be the same, anyone?
Old Mar 18, 2009 | 06:21 PM
ej1love's Avatar
can anyone confirm 2 and 4-door integra rear lca's are the same?
Old Mar 18, 2009 | 07:16 PM
ivicr's Avatar
should be the same lca
Old Mar 18, 2009 | 07:31 PM
ej1love's Avatar
thanks the integra guys helped me out, they are the same...
Old Mar 19, 2009 | 09:23 AM
ivicr's Avatar
Kool, GL with your build !
Old Mar 19, 2009 | 04:37 PM
ej1love's Avatar
1 lingering question? on the 4-door teg i ripped the sways off, the rear had a bracket attatched to the bracket(lol) that goes to the subframe...its like the ''u'' bracket wasnt close enuff. idk... i need that i've never seen that piece b4.
Old Mar 19, 2009 | 04:45 PM
BlueIntegraBoy's Avatar
Old Mar 19, 2009 | 04:55 PM
ej1love's Avatar
thanks a lot... yea i have the complete swaybar w/ endlinks and rear lca's. #7 or whatever i have those two. i guess it wold be 12/13 im talking about...in pics on civics thou ive never seen this bracket, sucks do i need this piece?
Old Mar 19, 2009 | 07:30 PM
ej1love's Avatar
do i need those brackets off the integra too, or just part #7's bracket? ?
Old Mar 19, 2009 | 07:55 PM
http://importnut.net/swaybar.htm
Old Mar 20, 2009 | 06:22 AM
ej1love's Avatar
*****... guess im goin back to the yard. argh! forgot to grab that bracket. thanks blueintegraboy!
JDogg
Suspension & Brakes
Apr 29, 2008 08:21 AM
fishnfst
16
Dec 14, 2003 11:27 PM
gsrpilot8000
Aug 19, 2002 01:09 AM
