rebuilt civic! Can i remove the main relay when i put switches in?
Old Mar 18, 2009 | 03:04 PM
06turbocivic18's Avatar
Default rebuilt civic! Can i remove the main relay when i put switches in?
im rebuilding my whole car. im am redoing the whole wiring. i have my turn signals, lights,rad fan,front wiper on switches. I am going to be putting my fuel pump on a toggle switch to. Can i do that and get rid of the main relay? Just need a ground and power for fuel pump to turn on right? I wont need the main relay? thanks..
Old Mar 18, 2009 | 03:08 PM
Default Re: rebuilt civic! Can i bypass the main relay with a toggle switch?
Old Mar 18, 2009 | 04:47 PM
fcm's Avatar
fcm
Old Fart
Default Re: rebuilt civic! Can i remove the main relay when i put switches in?
The PGM -FI Main Relay is two relays in one, one supplies power to the fuel pump, controlled by the ECU, [supplies a ground to relay coil] the other relay is the injector relay, it supplies power to the injectors, ECU and a few engine sensors, it is controled by the ign. switch, [supplies 12V+ to relays coil] so, no you can not get rid of the main relay, unless you do a lot of rewiring. 94
Old Mar 18, 2009 | 05:15 PM
do you know a link? i am re wiring everything i can. less wires in back neater look. this car is 100% stripped. Is there way can leave the main relay for the injectors and just have the fuel pump on a toggle switch to manual turn on?
Old Mar 18, 2009 | 05:17 PM
ill keep the main relay. i just wondering if i can cut the wires to the fuel pump and leave the main relay and then wire my new fuel to a toggle?
Old Mar 19, 2009 | 06:15 AM
fcm's Avatar
fcm
Old Fart
You would eliminate one lead, [ECU control lead] only to replace it with another, a fused 12V+ to a toggle switch, [and the switch].
I don't see the point, as it does not eliminate any wiring. 94
Old Apr 24, 2009 | 07:17 PM
south504's Avatar
this sounds like what im doing. i got rid of all factory wiring, and took apart the engine harness and used only what i needed.
i also picked up a painless type kit for the rest of the car so no more main relay for me, just switches.
fusion645
Audio / Security / Video
May 13, 2010 09:10 AM
Discontained
Sep 8, 2006 10:13 AM
EG6LS
May 22, 2006 09:30 PM
DnB TeK
Jun 22, 2005 02:46 PM
budlight
Aug 22, 2003 10:03 AM
