CEL Help on a 95 CX hatch
Old Mar 18, 2009 | 02:44 PM
401RIguy's Avatar
Default CEL Help on a 95 CX hatch
ive been tryna figure out what can be the problem! but then seem to not be able to check the CEL!
for some reason when i plug in the Wire to chek the CEL it wont BLINK! it'll just stay on and it wont make no move at all!
okay so as of 3/23/09 i just checked my IACV and when i UNPLUGGED THE SENSOR IT WONT IDLE NO MORE! But then when i PLUG it back in it IDLES Up and Down!
does this mean my IACV is bad or no?
please respond
Old Mar 18, 2009 | 03:00 PM
95hatch_007's Avatar
Default Re: CEL Help on a 95 CX hatch
are you putting it in the three prong or the two prong clip??
401RIguy's Avatar
i try all of them i think! hopefully i did!
Old Mar 18, 2009 | 03:01 PM
401RIguy's Avatar
which one do i put it in?
Old Mar 18, 2009 | 03:12 PM
joelmatt89's Avatar
it should be in the 2 wire plug, the only reason i can think it would stay on is if you start the car with it in there
Old Mar 18, 2009 | 03:52 PM
Pothole987's Avatar
the blinky light should blink when the ignition is in the on position. (without engine running)
if not, borrow an ECU from a friend. Most likely the ECU
Old Mar 19, 2009 | 04:42 AM
401RIguy's Avatar
im not sure! think i started the car with the wire in! ill try again in a bit
i can sure borrow another ecu also if its needed! thnxs
Old Mar 19, 2009 | 10:01 AM
fast_4_door's Avatar
with the jumper in, it should blink away whether the car is turned on, or if the key is only in the on position.
Old Mar 19, 2009 | 01:16 PM
401RIguy's Avatar
this is the first car i had with a CEL on! and Damn its a Pain in the a++!!! i cant find out whats wrong with it!
it wont blink if the car is on or not! DANGSSSSSSs
i have no clue what can be the cause of this!
Old Mar 23, 2009 | 02:29 PM
401RIguy's Avatar
found another solution to it now! please help
Shollman
Apr 22, 2017 03:17 PM
rhoades
10
Dec 28, 2009 12:42 AM
delsol21061
Mar 20, 2008 12:15 PM
vbherrera
Sep 19, 2006 08:06 AM
boonacka
Sep 5, 2006 07:04 AM
