Help with motor not starting.
Hi guys,
My d15 motor in my 94 civic is not turning over.
I recently just swapped the original motor for this one.
Need help locating the fuel pump fuse that needs to be pulled in order to perform a compression test.
My fuse box in the engine bay has no diagram so if anyone has it that would be helpful.
So far I've checked for spark which I have
About to check for fuel when I finish this post and go back outside.
Timing is on
Oil & coolant in the motor.
anything else i should check for that I might be forgetting?
Thanks
James
Timing is on
Thanks
James
