Quick question about cel before i go and look at crv
Hi,
I am going to go look at a 2001 CRV EX for sale and the check engine light is on.
I am familiar with checking them myself in the 96-00 civics by using a paperclip in the plug near the ecu. My question is, can I also do this for the CRV? Is the ecu located by the passenger kick panel as well?
Also any other things I should be looking at with a CRV that has close to 200K miles?
Thanks guys!
Thanks guys!
2001 CR-V
Change rear differential fluid
Hopefully you don't pull the CEL in this TSB for the cylinder head: http://www.in.honda.com/Rjanisis/pubs/SB/A03-038.PDF
CEL P1457 is the EVAP Bypass Solenoid Valve
Broken rear trailing arm bushings: http://www.in.honda.com/Rjanisis/pubs/SB/A00-006.PDF
