How can i improve my steering??
Old Mar 18, 2009 | 06:26 AM
Jaujau's Avatar
Default How can i improve my steering??
Hi,i´m from Spain
I have and EK,and i hate it steering because i think that it´s so soft. I would like that my steering becames harder
What can i do?¿
thanks
Old Mar 18, 2009 | 06:27 AM
hard_boiled_EG's Avatar
Default Re: How can i improve my steering??
if you have power steering remove it...
Old Mar 18, 2009 | 06:34 AM
Jaujau's Avatar
yes,i have power steering I don´t want to remove it, i only want it became harder...
Old Mar 18, 2009 | 06:39 AM
TeamRPM_ZC's Avatar
that is the only way to make you steering "harder"
without powersteering you have no help and its only you steering the car
so if you want your "harder steering"
take off the powersteering
Old Mar 18, 2009 | 06:54 AM
Jaujau's Avatar
i,m agree,but i think that if i remove the power steering it becanes too muuch harder
Old Mar 18, 2009 | 06:57 AM
TeamRPM_ZC's Avatar
if you have some mucles
then it wont be that hard
my homie is scrony, really scrony and have an Si with B20 with no powersteering and had no problems driving it.
youll get used to it after a while i guess
Old Mar 18, 2009 | 07:02 AM
Jaujau's Avatar
thre´s no other solution?¿
Old Mar 18, 2009 | 07:20 AM
B16AGUY's Avatar
Non.
No hay otra solución amigo.
Ma, cuando el civic se está moviendo él será mucho más fácil de dirigir que cuando él y se parquea.
Translation:
No.
There is no other solution friend.
But, when the civic is moving it will be much easier to turn the wheel compared to when it's parked.
Old Mar 18, 2009 | 07:23 AM
White civic's Avatar
there is alot of car with tight steering,also has power steering
Old Mar 18, 2009 | 08:52 AM
EK_B's Avatar
I'm wondering if he means he wants a stiffer suspension....
Old Mar 18, 2009 | 09:05 AM
Scott.'s Avatar
i dont have powersteering and i love it.
Old Mar 18, 2009 | 09:08 AM
alphalanos's Avatar
Thats what I think. In that case, stiffer springs and upgraded dampers will make your steering more responsive. Also larger wheels, maybe 16" will increase response.
Old Mar 18, 2009 | 02:08 PM
rack
Old Mar 18, 2009 | 02:15 PM
JDMgunmetalCRX's Avatar
i know the answer for you my friend.
replace your 2 front tires with BALD tires.
that **** makes ur car hard to steer no matter what. especially with no PS.
get some old *** tires on them front 2 shindigs
Old Mar 18, 2009 | 02:22 PM
this guy wants responsive and soft
Old Mar 18, 2009 | 02:26 PM
i really dont understand why u'd want to make it harder for u to steer it.
i'd kill to have PS response without the PS itself.
Old Mar 18, 2009 | 04:28 PM
Jaujau's Avatar
To kill the power steering i just have to remove the power steering engine¿?
Old Mar 18, 2009 | 04:34 PM
SOHCNightmare's Avatar
what about a steering quickener? i read about it in another thread... it goes inline with the steering column and takes out a whole turn lock 2 lock.
Old Mar 18, 2009 | 04:39 PM
it feel the same ****,if you take it off
Old Mar 18, 2009 | 06:24 PM
ej1love's Avatar
is removing power steering as simple as taking it all off? or do you need to change/modify anything? id like to shed a few lbs but need to know if i need anything...
Old Mar 18, 2009 | 06:48 PM
newtron63h's Avatar
to jaujau:
unfortunately there is a language barrier, you can write english very well BUT it is still hard for us to understand what you mean by "harder steering."
if you could exactly explain what the car does that you dont like, it would help us find your solution.
is the steering too easy for you?
or does the car move too much when turning?
Old Mar 18, 2009 | 06:57 PM
Originally Posted by newtron63h
to jaujau:
he means the steering wheel is not sharp and direct,i guess most civic owner has this problem
Old Mar 18, 2009 | 07:32 PM
newtron63h's Avatar
thats what i think he means, but i just want to be sure.
if thats the case, ive noticed this is how most japanese setup their steering. quite a bit of assist. europeans tend to not assist as much. and its a tradeoff. less assist gives more feedback, more effort. more assist gives less feedback and less effort.
i see a few options here:
1) leave things alone and just deal with it.
2) take off the power steering belt.
3) take off the power steering belt and remove the pump, with the lines on the rack running in a loop
4) non power steering rack.
those are the options i see.
Old Mar 18, 2009 | 07:36 PM
raidacaipo's Avatar
wear racing gloves everytime you drive :p
Old Mar 19, 2009 | 03:07 AM
Jaujau's Avatar
Sorry my English please!!
I means that my steering is too easy to me
