Idle Screw - Can it be taken out and replaced?
Old Mar 18, 2009 | 05:39 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Icon6 Idle Screw - Can it be taken out and replaced?
The idle screw on my 91 CRX HF is chewed up. Can I back it out 100% and replace it? Is some spring or anything going to come out and be a problem? From the parts diagram it looks like I can just replace it.
Anyone know the length/thread pitch if I go to Home Depot at lunch?
Thank you!
Old Mar 19, 2009 | 04:30 AM
Default Re: Idle Screw - Can it be taken out and replaced?
Some one has had to have done this... right? Also, would plumbers tape be a bad idea?
Old Mar 19, 2009 | 11:12 AM
Crx Jimmy's Avatar
yes it comes right out. if the slit is all chewed up just grind a new screw slit and replace the o-ring that is on it. I wouldnt use a home depot bolt
Old Mar 19, 2009 | 12:14 PM
Does it have a special taper or something? O-ring you say? I wonder about ordering it from Honda? hmmm.
Old Mar 24, 2009 | 04:32 PM
It has a special taper at the end, and 1 or 2 orings built into it...
I took mine out (just barely) and dremelled a new, deep slot. It also had red-lock tite on it, and was brass or some soft metal... not sure if it's original, my other CRX has a grey screw, and it is much closer to 'out' than this one... I wonder which was factory...
Old Mar 24, 2009 | 04:49 PM
gator88's Avatar
mine is grey and as you say, close to out at the stock settings. I know for a fact it is original as I am the original owner. This is the stock setup though....
Old Mar 24, 2009 | 05:33 PM
shaggyeg6si's Avatar
I have seen brass screws, and other are just aged brass. If you replace it, replace it with another another throttle body. There is a taper on it, it screws into a seat that allows air to pass around the throttle plate. Loctite is not neccessary, but a good idea. Although that's how the screw gets chewed up in the first place.
240punk
Jan 20, 2011 03:46 PM
nY's FiNeSt
Nov 19, 2005 09:55 AM
teamorange
Apr 25, 2005 10:23 AM
cbrf-3
Nov 27, 2004 10:36 AM
93SSPHatch
Aug 2, 2002 08:06 PM
