spoon calipers vs endless/zeal 6 pot calipers?
Old Aug 12, 2002 | 09:33 PM
ryu12341's Avatar
Default spoon calipers vs endless/zeal 6 pot calipers?
has anyone had experience with these two? deciding between the 2 any input would be greatly appreciated, thanks!!!
Old Aug 12, 2002 | 09:35 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: spoon calipers vs endless/zeal 6 pot calipers? (ryu12341)
Spoon is JDM!!
Old Aug 12, 2002 | 09:39 PM
B2FiNiTY's Avatar
Default Re: spoon calipers vs endless/zeal 6 pot calipers? (Rguy)
Actually both. Endless is a bit pricier but I have no comparison of both.
Hybrid ctr's Avatar
Endless/Zeal is JDM too
Old Aug 12, 2002 | 09:40 PM
gymkhana's Avatar
so you think endless isnt "jdm"
Old Aug 12, 2002 | 09:43 PM
Junior_r's Avatar
Default Re: spoon calipers vs endless/zeal 6 pot calipers? (gymkhana)
Endless is PDM, Pakistan Domestic Market. lol
Old Aug 12, 2002 | 09:46 PM
Hybrid ctr's Avatar
Default Re: spoon calipers vs endless/zeal 6 pot calipers? (Junior R)
I would take AP Racing over Spoon and Endless/Zeal anyday
Old Aug 12, 2002 | 09:53 PM
ahcjar103's Avatar
Default Re: spoon calipers vs endless/zeal 6 pot calipers? (Hybrid ctr)
spoons are pretty. 1500 pretty.
Old Aug 12, 2002 | 09:56 PM
koy's Avatar
koy
New User
Default Re: spoon calipers vs endless/zeal 6 pot calipers? (ahcjar103)
Endless makes 6-pots for ITR's??? i thought the 6-pot were for bigger cars like skylines,supras,etc...
Old Aug 12, 2002 | 10:13 PM
AJ PwR's Avatar
Spoon calipers can fit under stock wheels/rotors/pads and they do not have much clearance issue for most common wheel on the market. Endless calipers , you will find a lot of wheel clearance problems.
Brakingwise, Endless is a bit better but price is way more than Spoon.
Old Aug 12, 2002 | 10:16 PM
N1Spec's Avatar
New User
yahhh.... AP ownz!
Old Aug 12, 2002 | 10:26 PM
Hybrid ctr's Avatar
Default Re: spoon calipers vs endless/zeal 6 pot calipers? (N1Spec)
N1Spec
How much did your AP Racing brake setup cost???
Review???
Old Aug 12, 2002 | 10:42 PM
N1Spec's Avatar
New User
app. $2700 USD?
how much do an AP kit go for there in the states????
stops good, im so used to the stopping power that when i jump into any other car..... they feel so **** lol. The pedal is firm.... braking is progressive although when its heated up it is abit sensitive and will anchor the car to a stop pretty damn quick. The best part of having big brakes is the confidence it gives you, especially at the track.
PS. i believe APRacing makes ENDLESS brake components.
Old Aug 12, 2002 | 11:11 PM
AJ PwR's Avatar
Spoons are only 1100-1300 range.
Old Aug 12, 2002 | 11:53 PM
DC2#428's Avatar
are you sure san?....i know AP racing 4 pot brake kit costs 2700 AUD.....i think your costs more than that!..lol!
and since the 6 pot and 4 pot AP racing calipers are pretty much the same in dimensions its hard to find wheels that would fit these puppies!.....
[Modified by DC2#428, 8:54 AM 8/13/2002]
Old Aug 13, 2002 | 10:02 PM
ITR#132's Avatar
Default Re: spoon calipers vs endless/zeal 6 pot calipers? (AJ PwR)
Is that the new pricing for Spoon Calipers? I want some for $1100. How much is shipping?
Old Aug 13, 2002 | 10:04 PM
Mike M's Avatar
Founding Member
Default Re: spoon calipers vs endless/zeal 6 pot calipers? (ITR#132)
Yes, give us a call
Old Aug 13, 2002 | 11:04 PM
ryu12341's Avatar
Default Re: spoon calipers vs endless/zeal 6 pot calipers? (TypeRmsm)
the spoons are light, how much lighter are they compared to stock itr calipers. also, since the endless 6 pot are heavier, would it be a noticeable difference in handling? also, would the stopping power of the endless negate the extra weight?
Old Aug 14, 2002 | 08:52 AM
AJ PwR's Avatar
Mike..... stop giving out cheap prices
Old Aug 14, 2002 | 08:54 AM
B2FiNiTY's Avatar
LOL
Old Aug 14, 2002 | 09:04 AM
Rob :190:'s Avatar
1. the spoons are light, how much lighter are they compared to stock itr calipers. 2. also, since the endless 6 pot are heavier, would it be a noticeable difference in handling? 3. also, would the stopping power of the endless negate the extra weight?
1.
Stock ITR ~13lbs
Spoon ~6lbs
2. dont know, but if the endless are lighter than stock, that is a good think
3. depends on how much bigger the pads they use. if they use the same size pads as the spoons (and stock ITR) then braking performance (braking distance at least) will not change
Old Aug 14, 2002 | 02:59 PM
Black R's Avatar
25 Year Member
Default Re: spoon calipers vs endless/zeal 6 pot calipers? ( Rob)
me = not so sure I agree with that statment... Do we have any empirical evidence to corroborate? I'm sure 4 pistons as opposed to 1 have something to do with it.....?
Old Aug 14, 2002 | 03:10 PM
Big Phat R's Avatar
Default Re: spoon calipers vs endless/zeal 6 pot calipers? (Black R)
If you're using stock sized rotors and pads (i.e. Spoon) then braking performance won't be hugely different. The main advantage to the Spoons is the improvement in unsprung weight. They will also have more even pad wear (again: pads are a wear item - who cares about even pad wear).
The 6 pots will likely overwhelm the braking friction your tires can generate - so you will probably just cause the ABS to kick in earlier. Weight advantages will be minimal plus you have to run a bigger rim and rotor (++weight)
To really improve braking performance in the Type R you need
1) bigger rotors (more swept area)
2) thicker rotors (more heat sink)
3) bigger pads
4) better cooling
5) and an LHT MC brace
Old Aug 14, 2002 | 03:12 PM
Black R's Avatar
25 Year Member
Default Re: spoon calipers vs endless/zeal 6 pot calipers? (Big Phat R)
.....so there you have it:
sp00n calipers actually shorten braking distance because they lighten up the car, giving it less mass to slow down and stop.
Old Aug 14, 2002 | 03:16 PM
Big Phat R's Avatar
Or you could take out the a/c, get a CF hood, lighter rims etc etc
