Need help mpfi swap!!
Ok im stuck on my swap i have a d16a6 with a vtec head i bought a full mpfi harness i have everything wired up its a obdo harness so i have a jumper harness,obd1 distributer and a p28 on the harness it has 4 wires thats has to go to the ecu its says connect one to a3 on the ecu and another its say connect to a7 and the others are c1 and c2 please help
Your location says columbus; that wouldn't be indiana would it?
C1 to blue/green wire on dist.
C2 to blue/ yellow wire on dist.
A3 to #2 injector (red)
A7 to #4 injector (yellow)
One injector is by your timing belt side, and four is closest to your distributor. I learned that by searching when i did my last couple mpfi swaps.
Its Columbus Ga.
Ok so the wires do not go to the ecu?
Performance Freaks EH
May 19, 2006 05:56 PM
ham
Jun 15, 2004 11:55 AM
