TPS help! it always reads 5V no matter what!!
Old Mar 17, 2009 | 07:29 PM
D A 9's Avatar
Default TPS help! it always reads 5V no matter what!!
Hey guys, just like the title says... My TPS always reads 5V, no matter what position it is in...
The motor is a jdm b16 in a 90 crx si, code 7, so I grabbed my multimeter, turned the key to the ON position (no engine running) tapped the yellow/white and green/white wires and found that no matter what position the TPS is it always reads 5 volts...
Is my TPS bad? Thanks for the help in advance!
Old Mar 17, 2009 | 07:57 PM
akandok's Avatar
Default Re: TPS help! it always reads 5V no matter what!!
if you are measuring the middle wire (signal) then yes, bad TPS.
Old Mar 18, 2009 | 04:15 AM
D A 9's Avatar
easy enough, thanks. I guess I'm visiting Honda today...
Old Mar 18, 2009 | 05:01 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Is that the same wire(s) I am looking for on a Stock 91 CRX HF? To test my TPS, that is.
Old Mar 18, 2009 | 06:31 AM
jlicrx's Avatar
checking between yellow/white and green/white should always give you 5V - to check the TPS to see if it is working correctly, you need to check the voltage between the red/blue and green/white wires
Old Mar 18, 2009 | 06:34 AM
shortyz21's Avatar
goto the junkyard and just snag a throttle body for 25$... since that stupid sensor is rivetted in.
Old Mar 18, 2009 | 09:35 AM
Does it matter if it's from an Si (and I have an HF). What about a DX? What about civics of similar vintage, must it be the exact same engine, or did they all use the same throttle body? (88-91 Crx/civic)
Old Mar 18, 2009 | 09:45 AM
D A 9's Avatar
I will definetely try that in a little while, I'll post results as soon as I have it! Thanks for the info!
Old Mar 18, 2009 | 09:47 AM
D A 9's Avatar
Hey Phoenix, let me know if you need an SI TB, I got one you can have, just pay for shipping... PM me if you're interested
Old Mar 18, 2009 | 10:55 AM
pm sent. Si same as HF?
Old Mar 18, 2009 | 11:38 AM
91DBSexyTime's Avatar
that or you can order the Omni Power one...mine is bad also, but I dont feel like buying a new TB just to get a TPS...the Omni Power one is around $80 but I seen it on other sites for around $60....Yeah Ive tried unplugging it and reseting the ecu then the CEL goes away but then after driving I see my throttle % needle on my controller go crazy,kinda miss fire while on throttle then the CEL comes on then it stops.
Old Mar 18, 2009 | 07:57 PM
D A 9's Avatar
thanks jlicrx, Problem solved, turns out I was checking voltage on the two wrong wires (G/W, Y/W wires) once I checked the R/B (middle wire) and G/W it worked fine after a quick adjustment, problem solved! No more CEL (on at least...)
Crex167
Jul 18, 2012 04:29 PM
edgeprox
May 18, 2011 09:42 AM
Einhander276
Feb 15, 2011 06:19 PM
Stoich
Jul 16, 2005 01:09 PM
7808
Sep 18, 2003 10:16 PM
