clutch wont engage!
Old Mar 17, 2009 | 06:59 PM
h22acd5's Avatar
Default clutch wont engage!
i have a 92 integra and recently my clutch will go down and wont come back up but at the same time it wont go in gear it will start if i push it all the way down but only once and i little white ring broke offf the cable im not sure what it was but it is small white and on the clutch cable so if you had any info that would be great..
Old Mar 17, 2009 | 08:06 PM
Armorzaku's Avatar
Default Re: clutch wont engage!
same problem happened to me, i bled the clutch and everything, took it to a shop to find out that it was the slave and master clutch cylinder, i would be willing to bet its either one of those, or even both.
Old Mar 17, 2009 | 10:48 PM
GsrHatcher's Avatar
wouldnt 92 have a cable clutch tho if so then would be the cable or throw out bearing
Old Mar 17, 2009 | 11:22 PM
Armorzaku's Avatar
if its the throw out bearing it would make a little wizz sounding when pressing in the clutch, he didnt mention that
Old Mar 18, 2009 | 03:10 AM
GsrHatcher's Avatar
well then its the cable... ur talking about the slave and master clutch cylinder when he said the white ring broke off the cable..
Old Mar 18, 2009 | 08:38 AM
h22acd5's Avatar
so what is that little ring called and where can i get it?
Old Mar 18, 2009 | 08:59 AM
artin01's Avatar
its yourrrrrrrrrrr master cylinder go chenge it $100 yup.
Old Mar 18, 2009 | 10:11 AM
GsrHatcher's Avatar
how can it be the master cylinder when he said he has a cable it would be cable trans there would be no master cylinder with a cableeeeeeee trans.............. u would need to buy a new cable..the lil ring is what holds the cable in place so it can pull the fork up and push the bearing out to engage the clutch
Old Mar 20, 2009 | 09:30 PM
h22acd5's Avatar
ok thanks i fixed it thanks alot guys
EB90RS
Sep 23, 2007 01:19 PM
MarksIntegra
Dec 22, 2006 07:02 AM
trooper0641
25
Dec 28, 2003 05:24 PM
greebler
Jan 26, 2003 01:38 PM
