info about a p28
I got a ecu of some guy n he said its a p28 but it don't have da sticker on da side so how do I check if its a p28 with out plugging it to my eg
To tell if it a P28 check if it is first check if the connector on the bottom is ODB1
next you will have to open up the ecu it should look similar to this
http://www.xenocron.com/install/ECU-...s/image004.jpg
also take note of the serials inside the ecu usually top left corner
and this will state what it is
92-5 ECUs (P28, P30, P61, P72, P91, P08)
5spd = 000, 001, 002, 003, A00, A01, A02, C00, C01, C02, J00, J01, J02
Auto = J50, J51, 901, 902, C50, C51, C52, A50, A51, A52
From the patterns we can learn the following:
-First letter = country of orgin
J = Japan
C= Canada
A=USA
-Second digit, if 5, 7, 9 then ecu is auto usually
-Third digit denotes the version/variation
Hope this helps
J = Japan
C= Canada
A=USA
Hope this helps
