strange no start issue. HELP!!
so i decided to take my crx sunday morning since i hadnt drove it in ages, let it warm up and took off down the road, got about a mile or two down the road and noticed the speedo was pegged at 120 and the center was glowing red, bout that time the needle fell off and the car died, got it back home (tow)and the fuel pump isnt priming, changed the ignition switch and main relay for a known good one nothing, still no prime or start, thought the ecu was bad and put it in my other car and fired right up, all the fuses are good and the fuel pump was installed 2 years ago (walbro 255) im thinking the power for the pump is under the cargo cover (correct if wrong) and im not getting any power at that point either, there was a relay of sorts in the fuse box that was making a funny sound and i changed that for another known good one and still nothing. im at a loss and normally im good at electronics but this is beyond me, and yes the grounds are good as the grounds on the motor thermostat housing
520_Motorsports
Jan 20, 2008 12:21 PM
