Headlights caught on fire....
Old Mar 17, 2009 | 04:40 PM
91EF919's Avatar
Default Headlights caught on fire....
ok well i was driving on a dark road so i had my high beams on for a long time, because it was a long road. I get to my house and i see the the passenger headlight glass is all black, and looks burnt, and its very foggy. So i took out the lights and the low beams were fine but the high beam light is all black and smokey. So now how can i clean my headlight i got most of the fog/smoke out, but it is still foggy, and the big black mark is making me mad. Is there any way i can take out the glass so i can clean it out? any ideas
Old Mar 17, 2009 | 04:51 PM
grog's Avatar
Default Re: Headlights caught on fire....
yes, remove all the metal clips and brackets from the housing, pop it in the oven on low 150-250 for 5-10 minutes (be carefull and watch it) this will heat the glue that bonds the glass enought to pull it off of the housing. make sure to seal back up good with something that can handle some heat and rain (outdoor rated)
you should also make sure there is'nt a problem with the high beams, check the voltage and the wiring.
btw the housing is plastic so it may have melted/burned the reflective coating, hopefully not though.
Old Mar 17, 2009 | 05:46 PM
Crx Jimmy's Avatar
if it's just smoke soot inside you don't have to remove the lens. Just take the headlight out and pour a couple ounces of denatured alcohol in and shake till it all dissolves. Dump it out and let it dry then re install.
Old Mar 17, 2009 | 07:16 PM
91EF919's Avatar
thanks, ima do what crx dummy said to do. How do i take out the headlight, how many bolts are there and where are they located, and is it a hard job?
Old Mar 17, 2009 | 07:30 PM
west nile's Avatar
Originally Posted by 91EF919
crx dummy
hahaha
Old Mar 17, 2009 | 07:43 PM
jhammond_82's Avatar
Reject Papi
lol
Old Mar 17, 2009 | 07:56 PM
akandok's Avatar
crx dummy
Old Mar 17, 2009 | 08:00 PM
h224thgensedan's Avatar
lol got three of the letters right
Old Mar 17, 2009 | 08:07 PM
4gen5thtime's Avatar
Its not hard, you should get a book on your car like a chiltons or haynes(tell's you alot about taking parts off). But there is the top adjuster bolt/screw you take out then one screw in the middle on the bottom, two on the out side edges and then you have two on the inside back like close to the rad. on the bottom. Then pull a little and it should come out after you have taken out the bulbs to. That should be it if you look around the housing you will notice all the screws.
Old Mar 18, 2009 | 10:06 AM
91EF919's Avatar
ok thanks. And i meant crx jimmy
H.
Oct 28, 2011 02:00 PM
vodkaTM
Feb 5, 2009 01:55 PM
hondanc7
Jul 4, 2008 02:04 PM
dLo GSR-stolen-now-WRX
May 20, 2002 08:51 AM
