What caliper did I get?
Old Mar 17, 2009 | 04:33 PM
91bluehatch's Avatar
Default What caliper did I get?
I recently ordered front and rear disc off of a ek4 sir from hmotorsonline. I was under the impression the front calipers are the same as the 96-00 ex/si, so I ordered hawk pads for a 2000 si. The pads look smaller than the worn out pads that came with the setup. The caliper number is 16cl14vn. Anyone have any idea what pads I should get?
Old Feb 25, 2011 | 12:36 PM
WheelPowerRacing's Avatar
Icon6 Re: What caliper did I get?
The caliper # can be misleading, as the bracket holds the pad and calipers can be swapped between brackets. The 16CL14VN caliper came on the 93-95 Civic EX Coupe without ABS, so the pad you need may be a D621. Take the worn pads down to the parts store, ask for a set of pads for a 1994 Civic EX coupe without ABS, compare them & verify. Hope this helps
Old Feb 25, 2011 | 12:39 PM
grumblemarc's Avatar
The Grumpiest
Default Re: What caliper did I get?
Pads for an EK4 SIR? Maybe I'm oversimplifying but I don't get the question.
http://www.google.com/search?q=brake...ient=firefox-a
Old Feb 25, 2011 | 05:56 PM
94EG8's Avatar
Seagull Management
Honda used like 3 or 4 different calipers on 10.2 in rotors, all use slightly different pads. Sometimes it's hard to figure out which USDM car corresponds to what caliper you have.
JDMTEG98
Honda Civic (2001 - 2005)
Jul 10, 2009 12:38 PM
91bluehatch
Suspension & Brakes
Mar 19, 2009 04:56 PM
skiracer8148
13
May 15, 2006 07:27 PM
Banned HT Member
Feb 25, 2006 06:24 PM
Viorent Grip! EG
14
Oct 20, 2005 10:36 AM
