Honda CRX issue?
Hey, I was looking to buy a honda CRX. The one im looking at, the guy told me that when you try to start going and take off to fast the car will start to bog down. Any idea's on what that could be? And maybe how much it would cost to fix. thanks
Does it also bog down when you take off normally or is it only when you try to launch the car? Does the car ever regain it's composure and get up and go or does it continue to bog?
check cOil....
Spark plugs...
and TPS sensor...
I would say the TPS because if the ecu can't see how open the TB is it won't give the right amounT of fuel..
Not enuff fuel =bog down
Not the right spark= bog dow..
Spark plugs...
and TPS sensor...
it is only when you floor it, and im not sure about if it regains its speed, but i am going to test drive it tonight and ill post again then
RUN SEAFOAM IN IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
MY CRX (2 of them) USED TO DO THAT!!!! RUN SEAFOAM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
DOOOOOOOOOOOOOOOOO IIIIIIIIIIIIIITTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!
TDRacing
Dec 21, 2002 08:00 AM
